Sunrider Door Surround Latch - JeepForum.com
post #1 of 3 Old 06-05-2012, 10:27 AM Thread Starter
d_rex
Hi guys, I've had my soft top stored for some time I finally have a garage and now I can put the soft top on again.
I put it on no trouble, on the driver side, but on the passenger side the sunrider won't latch into the door surround. I can get it in there but it pops out. Does any one have a similar issue? How about the part number for the latch? In looking for the part number I can find whole surround (55395236AF) not just the latch though. I have been searching the forum and can't find any similar issues.
Thanks for any help.
d_rex is offline
post #2 of 3 Old 06-05-2012, 11:31 AM
Jiblet
I've had trouble before and always double check those latches making sure they click in before I hook the windshield patches or the sail panels.
Maybe try un doing everything and start over with passenger-side latch.
Have you inspected the spring in the latch itself? Maybe a (minimal) spritz of lube into the latch would help.
Jiblet is offline
post #3 of 3 Old 06-05-2012, 01:25 PM Thread Starter
d_rex
Yeah I have taken both of them off to see if I could see any difference between that one and the driver side. No luck. Good idea I'll get a little WD-40 in there to see if it might seat a little better, thanks!
d_rex is offline
parts identification , soft top , sunrider
Door surround don't fit? cheesycook TJ Wrangler Technical Forum 4 09-16-2011 07:20 PM
LJ sunrider door surround clips Aalbury TJ Wrangler Technical Forum 1 06-16-2011 03:33 PM
TJ/LJ Door Surround Pin Manateu TJ Wrangler Technical Forum 1 01-21-2011 07:01 PM
door surround use samrob TJ Wrangler Technical Forum 11 04-24-2009 11:47 AM
Door Surround latch with Bikini Top? XpensiveWino JK Wrangler Technical Forum 3 05-10-2008 09:09 PM
