suggestions for door pin grease - JeepForum.com
post #1 of 14 Old 05-29-2013, 02:39 PM Thread Starter
doliss
2009 JK Wrangler
Do y'all use anything specific or should anything work well?
doliss is offline
post #2 of 14 Old 05-29-2013, 02:45 PM
2Five22
Lithium grease works well, but if you drive where road/sea salt are issues, you might try anti-seize compound if you like to take off the doors seasonally. It makes removal a bit less of a struggle.
'13 JK Rubicon in white - the German Shepherd's
'13 JKU Sport in gecko - her Majesty's
I am just the chauffeur.
2Five22 is offline
post #3 of 14 Old 05-29-2013, 02:52 PM
ronjenx
ronjenx's Avatar
Search for Delrin hinge bushings. You won't have to lube them ever again.
ronjenx is online now
post #4 of 14 Old 05-29-2013, 04:07 PM
SubAtomicGenius
2011 JK Wrangler
And if you get the delrin, don't grease them. I think that they are OK with white grease, but everything else makes delrin swell up.
I got the delrin bushings in myself,however, I lubed them up with white grease when I inserted them, mainly to prevent everything else from rusting. Good upgrade if you get them on sale, got mine for half-price.
SubAtomicGenius is offline
post #5 of 14 Old 05-30-2013, 05:38 AM
Wavedatya
2010 JK Wrangler
I use a heavy multi purpose grease. It stood the test of winter. This spring my doors came right out. No mess either. Apply and wipe and leftover. Done.
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #6 of 14 Old 05-30-2013, 06:07 AM
Deuskid
I plan on going doorless whenever it is warm enough and since I live alone being able to remove them by myself is paramount. Good info here. Thx
Deuskid is offline
post #7 of 14 Old 05-30-2013, 01:38 PM
SubAtomicGenius
2011 JK Wrangler
For the standard bushings and pins, I'd use a clear dielectric grease called Superlube. That **** is the bomb. Doesn't smell, doesn't wick away, doesn't wash away, not affected by salt, and it's non-toxic. Expensive, but it does 1000 jobs.
post #8 of 14 Old 09-10-2013, 04:08 PM
Deuskid
How did you find them on sale?
I can only find one source when I googled 'delrin bushings'
Thanks,
John
Deuskid is offline
post #9 of 14 Old 09-10-2013, 06:18 PM
SubAtomicGenius
2011 JK Wrangler
post #10 of 14 Old 09-18-2013, 04:40 AM
Jeepin It
Jeepin It's Avatar
I just use wheel bearing grease. It's all I had. Works fine for me.
Chris
2012 JKU Sahara
RIP
2004 TJ Sahara
RIP
1992 YJ Renegade.
Jeepin It is offline
post #11 of 14 Old 09-18-2013, 11:08 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
The problem with grease is that dirt sticks to it when you run without the doors. Be sure to clean before putting doors back on!
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #12 of 14 Old 09-18-2013, 12:09 PM
irishluck
Use the kind that's greasy!
irishluck is offline
post #13 of 14 Old 09-18-2013, 05:44 PM
HAFICON
Never put doors on and no need for grease...
But I use Ant seize instead of grease it works fine for me.
315/70/17 Duratrac on MB Wheels
AEV 2.5 with M.O.R.E 1" body lift
Viair 450c, ARB Air lockers,
4.88's and TNT truss.
My build thus far.
HAFICON is offline
post #14 of 14 Old 09-20-2013, 06:35 AM
OH9JK
2009 JK Wrangler
astroglide?
OH9JK is offline
