Stuck in Neutral - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Stuck in Neutral
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 01-04-2015, 05:29 PM   #1
EvanJohnson
Stuck in Neutral
I received a call from a relative earlier asking me what may be wrong with his jeep. He explained to me that he had put his '14 automatic rubicon in neutral in order to tow it behind a motorhome. Once he tried to take it out of neutral, it would not go back to 2HI, 4HI, or 4LO. When he started it would grind when he tried to put it in gear, but wouldn't engage. What might be causing this? Any suggestions are much appreciated, thanks!
EvanJohnson is offline   Reply With Quote Quick reply to this message
Unread 01-04-2015, 08:01 PM   #2
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Couple of questions. I just read my owners manual on towing mine which is an '11 but should be the same as a '14. A couple of things that were stressed, were that it not be towed on a dolly, meaning with only 2 wheels on the ground (front or rear), and that it only be towed in a forward direction with the transmission in park. Did he ensure/verify that the xfer case was in neutral? If any of these things were done/not done then severe damage could have been done to the xfer case.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
www.militaryjeepers.com lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline   Reply With Quote Quick reply to this message
Unread 01-04-2015, 08:30 PM   #3
zjilla
have them put the tranny in neutral when switching the tcase out of neutral. that would eliminate some human error at least.
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
www.annirlane.blogspot.com
October 2013 JK of the month
My Slowly but surely JK build thread:
http://www.jeepforum.com/forum/f96/s...hread-1562595/
zjilla is offline   Reply With Quote Quick reply to this message
Unread 01-09-2015, 08:21 AM   #4
michiganmaveric
Got Beer?
2011 JK Wrangler
Any update on this?
Lifetime member #13
