stuck joint in tie rod - JeepForum.com
post #1 of 12 Old 10-26-2013, 06:31 PM Thread Starter
TXWK131
2009 JK Wrangler
I was able to get the driver side joint out with no problem but the right side I cant get out for the life of me... 2 vices briken wd 40 nothing with make it break loose any suggestions... much appreciated
2009 SILVER JK Sahara
RC 3.5-315.70.17 on Stock RUBI's
PE Front and Rear Bumper
DIY DECK LID
2006 Navy WK HEMI ~RK 3.5 lift - 17" Moabs - Toyo 265.70.17 AT - Bedliner Paint Job - SOLD
'85 XJ... Still tryin to figure out what the heck I have in this piece of Junk! But you gotta start somewhere
TXWK131 is offline
post #2 of 12 Old 10-26-2013, 07:04 PM
TheBoss
Pretty sure only the drivers side is removable. If your replacing with stock items the weak link is still the rod itself. It flexes like a wet noodle.
TheBoss is offline
post #3 of 12 Old 10-26-2013, 07:30 PM
222Doc
222Doc's Avatar
The right side is stamped on. The stock tre's are so lose you can flop it around brand new. Like boss said they flex to much as well as the drag link is ever worse.
I really like the Poly/Synergy tie rod and drag link(though I believe the drag is for flipped only) and new ball joints. My Jkr has not had this nice a feel even NEW. feels so positive now. all my stock steering parts went out at about 16-20k.
222Doc is offline
post #4 of 12 Old 10-26-2013, 07:35 PM
TheBoss
The Synergy drag can be used without a flip. When my junk breaks I'll justify the upgrade.
TheBoss is offline
post #5 of 12 Old 10-26-2013, 09:24 PM
222Doc
222Doc's Avatar
It would be very tight to have one above the other. If Synergy says it will work it must. I mean even the zerks might touch each other it looks that close
I know on 15" rims its way close to tie rod ends to rim. Some I hear wont work. Metal rims are thin though and I think that helps. but I have 3.75 off set so its clear of the 15'
He Boss next year man. Trifecta of trails. hard core run
Rubicon(Tahoe to George town)/Fordyce( a real 10)/Dusy(no air bags for me) 10 days of wheeling, camping and the best of in Cali. My plans for summer 2014 and some clubs.
222Doc is offline
post #6 of 12 Old 10-27-2013, 05:38 AM
TheBoss
Hum.... sounds like a make it or break it for my rig ha, ha. We'll see if I can finally get 35's working under it without calamity. That does seem to be worth the drive how many days would that take?
TheBoss is offline
post #7 of 12 Old 10-27-2013, 07:21 AM
krawler510
Are you talking popping the tre out of the knuckle?
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #8 of 12 Old 10-27-2013, 07:43 AM
TheBoss
I do believe he was trying to separate both tie rod ends from the assembly ,already off the knuckles.
TheBoss is offline
post #9 of 12 Old 10-27-2013, 09:54 AM
222Doc
222Doc's Avatar
Pm to not derail the thread.
222Doc is offline
post #10 of 12 Old 10-31-2013, 06:41 AM Thread Starter
TXWK131
2009 JK Wrangler
Ghanks for the help fellas I just ended up replacing everything!
DIY DECK LID
TXWK131 is offline
post #11 of 12 Old 10-31-2013, 06:27 PM
TheBoss
What did you end up using?
TheBoss is offline
post #12 of 12 Old 11-02-2013, 05:34 PM Thread Starter
TXWK131
2009 JK Wrangler
Teraflex drag, tie rod, track bar... Synergy HD ball joints no mote DW!
DIY DECK LID
TXWK131 is offline
