stuck door (as in won't even open) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > stuck door (as in won't even open)
AMP Research Powersteps - A Morris 4x4 Center PromotionCrawler Conceptz at JeepHut.comTime To Save On Yukon Lockers!
Unread 05-25-2013, 06:12 PM   #1
mrcoyote
Really weird.. I was just in the passenger side (front) to remove some tools I had on the floor while doing some electrical work. Close the door. And now it won't open! It almost seems like the hinges have siezed up - the door opens about 1-2" and thats it - try to pull and I'd be worried about bending something somewhere.
This is a 2012 JK!
Any ideas?!?
mrcoyote is offline   Reply With Quote Quick reply to this message
Unread 05-25-2013, 07:02 PM   #2
222Doc
one thing about Jeepforum. In time you will hear it all.
Just an off chance. Is there something stuck at/in the door strap?
Sticky goo on the door seals from say a airent icecream cone or other kid stuff?
The hinges are nothing but a pin. you could remover the bolts? see if that losens it up.
first post I have seen of this nature. best of Luck
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is online now   Reply With Quote Quick reply to this message
Unread 05-25-2013, 07:03 PM   #3
JTPhoto
Remove torx nut from bottom of hinge pin, Spray penetrating oil on the hinges and let sit to soak in. Reapply the next day if needed. Once you are able to get the door open, remove door clean pins, grease and reinstall.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 37x12.50x17 Pitbull Rockers on ProComp 7069 Alloys, AEV Prem Bumper ETC..
JTPhoto is offline   Reply With Quote Quick reply to this message
Unread 05-25-2013, 08:11 PM   #4
222Doc
seems odd its a 012, he just opened the door and went to reopen it. now its rusted closed? must be something simple.
Unread 05-25-2013, 08:22 PM   #5
JTPhoto
I agree, but there is only so much that can go wrong with a simple pin hinge.
^^Jeff^^
Unread 05-26-2013, 11:32 AM   #6
mrcoyote
Simple and so incredibly stupid..... the extra length of the grab handle strap came loose from how I have it 'tucked' and got stuck in the window when I put it up.
I immediately reversed all my grab handles so if(when) the extra length comes loose again, it'll fall 'inside' the Jeep and not out the window!
Unread 05-26-2013, 01:14 PM   #7
socal_rubi
Don't feel bad, the same thing happened to me
socal_rubi is offline   Reply With Quote Quick reply to this message
Unread 05-26-2013, 02:58 PM   #8
222Doc
Knew it was something simple.
Trust me the older you get the more things go FUBAR.
