stuck door (as in won't even open) - JeepForum.com
post #1 of 8 Old 05-25-2013, 05:12 PM Thread Starter
mrcoyote
Really weird.. I was just in the passenger side (front) to remove some tools I had on the floor while doing some electrical work. Close the door. And now it won't open! It almost seems like the hinges have siezed up - the door opens about 1-2" and thats it - try to pull and I'd be worried about bending something somewhere.
This is a 2012 JK!
Any ideas?!?
mrcoyote is offline
post #2 of 8 Old 05-25-2013, 06:02 PM
222Doc
222Doc's Avatar
one thing about Jeepforum. In time you will hear it all.
Just an off chance. Is there something stuck at/in the door strap?
Sticky goo on the door seals from say a airent icecream cone or other kid stuff?
The hinges are nothing but a pin. you could remover the bolts? see if that losens it up.
first post I have seen of this nature. best of Luck
222Doc is offline
post #3 of 8 Old 05-25-2013, 06:03 PM
JTPhoto
JTPhoto's Avatar
Remove torx nut from bottom of hinge pin, Spray penetrating oil on the hinges and let sit to soak in. Reapply the next day if needed. Once you are able to get the door open, remove door clean pins, grease and reinstall.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #4 of 8 Old 05-25-2013, 07:11 PM
222Doc
222Doc's Avatar
seems odd its a 012, he just opened the door and went to reopen it. now its rusted closed? must be something simple.
222Doc is offline
post #5 of 8 Old 05-25-2013, 07:22 PM
JTPhoto
JTPhoto's Avatar
I agree, but there is only so much that can go wrong with a simple pin hinge.
^^Jeff^^
JTPhoto is offline
post #6 of 8 Old 05-26-2013, 10:32 AM Thread Starter
mrcoyote
Simple and so incredibly stupid..... the extra length of the grab handle strap came loose from how I have it 'tucked' and got stuck in the window when I put it up.
I immediately reversed all my grab handles so if(when) the extra length comes loose again, it'll fall 'inside' the Jeep and not out the window!
mrcoyote is offline
post #7 of 8 Old 05-26-2013, 12:14 PM
socal_rubi
Don't feel bad, the same thing happened to me
socal_rubi is offline
post #8 of 8 Old 05-26-2013, 01:58 PM
222Doc
222Doc's Avatar
Knew it was something simple.
Trust me the older you get the more things go FUBAR.
222Doc is offline
