stuck brake - JeepForum.com
post #1 of 7 Old 08-31-2012, 10:37 AM Thread Starter
scrambled
stuck brake
I have a 2008 sahara with a stuck right front brake. Anyone have this problem on theirs? Best way to fix it? thanks in advance!
2014 JKU Rubicon X-2002 Grand Cherokee Limited
Past: 2003 TJ Rubicon, 2006 LJ Rubicon Rubitrux
scrambled is offline
post #2 of 7 Old 08-31-2012, 11:25 AM
tavic
2010 JK Wrangler
Last time someone had this issue they had to replace the caliper.
tavic is offline
post #3 of 7 Old 08-31-2012, 12:35 PM
N2rock
N2rock's Avatar
yup- had that problem on my '07 a couple months ago. I didn't even bother trying to fix it. I just ran to Auto Zone and bought a new caliper (around $100)
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #4 of 7 Old 09-01-2012, 05:22 AM
Jpxfactor
I have an 08 .. replaced rotor and caliper .. still sticking .. so I had to replace the flex line and that fixed it.
Jpxfactor is offline
post #5 of 7 Old 09-05-2012, 04:01 PM
shenejm
2009 JK Wrangler
I have a 09.. Had the same issue... same wheel.. replaced the rotor.. caliper and the flex line...
shenejm is offline
post #6 of 7 Old 09-05-2012, 06:41 PM
Spanky916
Same problem on my '08 X on the left front. Noticed it on the way home from the dealer the day I took delevery. Replaced the rotor which was warped, $35, and caliper, $80ish. Problem gone!
Spanky916 is offline
post #7 of 7 Old 09-06-2012, 08:58 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Stuck brakes can be either hydraulic or mechanical.
The brake hose is a four ply. Its common (in ALL vehicles) for the plys to separate and the hose act like a check valve - especially if you have stretched the hose such as articulation with a lift...
Pop the bleeder while its "stuck" (if the hose is holding back pressure the bleeder will release it - you'll then know its the hose). If popping the bleeder does not release the stuck - then the sticky is mechanical - not hydraulic - and rotor, caliper and pad replacement is needed.
Or simply change the hose first and see if the problem goes away (but then rebleeding becomes a pain) - unless its already due for a brake job, then go ahead and spend on a loaded caliper set and hose.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is online now
Stuck brake herklord TJ Wrangler Technical Forum 1 07-09-2012 10:31 PM
Brake lights stuck ImportInvasion TJ Wrangler Technical Forum 4 06-06-2011 07:36 PM
E brake stuck OnlyOneKeano YJ Wrangler Technical Forum 6 02-13-2011 08:54 PM
brake stuck? hesserdude07 YJ Wrangler Technical Forum 6 05-22-2010 06:07 AM
After replacing calipers and rubber brake lines, my brake is still stuck! Dmcastino TJ Wrangler Technical Forum 23 06-25-2009 11:21 PM
