Struggling - Beadlock or Not - JeepForum.com
post #1 of 79 Old 11-03-2012, 06:12 AM Thread Starter
Orange1
I am moving to Arizona with my newly (and fully) upgraded 2012 ULTD w/ 35" tires. Wondering if beadlocks are recommended when running Class 3.5 mountain trails and river beds?
Orange1 is offline
post #2 of 79 Old 11-03-2012, 06:36 AM
jrallen
Traditional beadlocks with the ring on the outside aren't street legal, so that'd be an issue if you ever plan to drive it on the road. Have you ever heard of Staun internal beadlocks?
jrallen is online now
post #3 of 79 Old 11-03-2012, 06:55 AM Thread Starter
Orange1
Not street legal? Crud! I will look at the Stauns, if they are required. Not sure how much I need to air down yet.
Orange1 is offline
post #4 of 79 Old 11-03-2012, 07:12 AM
jrallen
If there's no inspection in Arizona, I don't really suppose it matters. I know here in Alabama my wheels could be made out of flaming dead babies and no cop would say anything. But here's a link of you wanna make the determination yourself...
http://www.liftlaws.com/are_beadlocks_street_legal.htm
post #5 of 79 Old 11-03-2012, 10:13 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Please reference the AZ code that makes them illegal. I can find no reference to wheels anywhere in the AZ codes - AZ Trans Code.
Do NOT quote DoT as DoT rules (which are standards not laws) apply to manufacturers (yes it WOULD be illegal for Jeep to use them on the units sold to the public) - NOT end consumers (you I and all other end consumers are NOT bound by DoT). A states "refusal to inspect" policy does NOT make them illegal either - it merely grants the inspecting station the right to refuse - a 1 hr job (checking torque on all the bolts) in which they only collect 12.00! - 8 of which goes to the state is NOT a profitable venture!
Until you can provide the code - please understand that just because you SAY they are illegal does not make it so in my opinion. Opinions and law are usually three different things!
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #6 of 79 Old 11-03-2012, 10:13 AM Thread Starter
Orange1
Looked at Florida (my current) and Arizona, neither have beadlock laws in place. The real question is whether beadlocks are recommended in Arizona, I would say it is probably preference.
Orange1 is offline
post #7 of 79 Old 11-03-2012, 10:16 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
If you are in sand or harsh rocks - and want to safely air down to less than 15 - beadlocks are the way to go. ANd this does not take into account cactus - I punctured a 10 ply sidewall on a cholla - drove back to camp with 0 psi!
post #8 of 79 Old 11-03-2012, 10:36 AM
jrallen
My bad, brethren. I was just letting him know he might want to check on the legality of beadlocks in his planned future area of residence before he spends $2,000 on a set and finds out he can't use them on the street.
post #9 of 79 Old 11-03-2012, 10:38 AM
jrallen
In that case, I'd suggest that you have them and, assuming you can afford them, they really have no down-side. It's always better to have and not need than to need and not have.
post #10 of 79 Old 11-03-2012, 10:45 AM
surfer459
Hutchinson bead locks are street legal! They look great too
surfer459 is offline
post #11 of 79 Old 11-03-2012, 10:50 AM
Wonk
I agree with the above about the legality of bead locks. In my opinion, internet myth. Go to AEV's web site. Pintlers are DOT compliant.
As to the OPs question. Bead locks will allow you to deflate tire pressure way below un-bead locked wheels (I usually crawled with the 37 x 12.50 KM2s mounted on Pintlers on my TJ at 6 psi rear, 7 psi front) You know best the type of wheeling you do and if you have a need for that low of pressures.
Wonk is offline
post #12 of 79 Old 11-03-2012, 10:54 AM
Tenshots1
Even if beadlocks were illegal, no cops would enforce it. if they did, most could be persuaded to believe you have "fake bead locks", which are all over the market. For inspection, simply borrow a pair of fellow jeeper tires and switch for a couple hours.
1998 XJ Build:
Tenshots1 is offline
post #13 of 79 Old 11-03-2012, 01:17 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Not really an INet myth - even before the INet, offroaders and even weekend drag racers have used em (with DoT cheater slicks of course) - its the "non DoT approved" thing that folklore has turned into an interpretation of "not legal". Most states DO have code that says tires must be DoT... so often the thinking erroneously gets extended to wheels.
Now question back to you - why split f/r pressures on the rocks - I just run 6 all the way around?
post #14 of 79 Old 11-03-2012, 01:35 PM Thread Starter
Orange1
Thanks for all the responses. I agree.........Hutchinsons are very nice wheels, and what I had in mind.
Any comments about Hutchinsons other than the expense?
I do have Goodyear MTR 315/70R17 which will fit 8.5" - 10.0" wheels (recommended 9.5"), the Hutchinsons are 8.5". Will the tires be a problem as they are on the edge of the range (I have zero experience with beadlocks)?
Orange1 is offline
post #15 of 79 Old 11-03-2012, 01:52 PM
surfer459
I have no personal experience but I have two buddies who have them on their Jeeps and they love them. They are expensive but supposed to be worth it.
