Straitening Steering Wheel - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Straitening Steering Wheel
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueECGS DOTW - $100 off Yukon 8.8 C-Clip Eliminator KitNitro Gear Packages Now Available at Rockridge 4wd
Unread 08-15-2014, 05:46 PM   #1
Rubedog302
i have a 2007 JK wrangler x and it was in small accident a while back but i noticed the steering wheel is upside down when the wheels are completely straight..and when the key is out it locks in that spot too. i have read many other forms on trying to adjust when you do LIFTS but as mine is stock, i tried to move the drag link turnbuckle that other people have said to adjust..im stuck still it didn't work..any suggestions would be greatly appreciated . would taking the steering wheel off and putting it on right side up be an option? new to owning a jk only a few months
Rubedog302 is offline   Reply With Quote
Unread 08-15-2014, 05:50 PM   #2
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Something is bent. Did you have it fixed after the accident?
Member of JGW (Jeff's Gone Wheeling) and IndyORV
My Old YJ Build My Mods My YouTube Channel
Shortcuts to key points in my build: MTRk's OME 2" HD Lift Antirock Skidrow steering box & radiator skids LoD rear bumper
Rokmen Mercenary bumper w/Superwinch Rokmen sliders Skidrow engine skid Rampage Top CB set up
Custom trunk Rokmen 1" Billet spacers JJ track bar Rokmen Adjustable Control Arms Currectlync Steering
Rokmen Trail Corners Metalcloak Overlines Kentrol Hood Latches JK Turn Signals Xenon 4" Flat Flares Hood Decal Duratracs
Derale Tranny Cooler DieHard Factor 55 Thimble Ten Factory Front Chromo Shafts
Get your build sheet here.
Jeffro06 is online now   Reply With Quote
Unread 08-15-2014, 07:35 PM   #3
Rubedog302
Not yet, I am actually about to replace the drag link/center link and tie rods.. The drag link looked bent anyways.. But as I'm looking at pitman arms online.. That may be bent too so I'm gonna probably replace that ..and then possibly see if that is what caused the whole thing to happen.
Unread 08-17-2014, 10:35 AM   #4
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Then do not take off the steering wheel. Replace the bent parts, then get and alignment.
Unread 08-17-2014, 11:25 AM   #5
ncb
This right here. Do not remove the steering wheel. I've attached a picture of the pitman arm with the wheels pointing straight. It will be clocked to the left with everything centered.
ncb is online now   Reply With Quote
Unread 08-18-2014, 08:38 AM   #6
Rubedog302
Awesome, yeah I actually messed with the drag link and I was able to straighten the wheel.. Pitman arm looks just like that.. For now, the esp bas turned off as I was driving around too , still need to get it replaced next week but for it's nice to have the wheel straight.. That was annoying but when I get the parts in I'll obviously have to re do the steering wheel and going to get it aligned and what not.
Unread 08-18-2014, 12:42 PM   #7
jwmbishop
2011 JK Wrangler
If you straighten the steering wheel - doesn't that make it a handlebar?
J Wm Bishop EA, ASADE
How to start an online argument - express opinion - wait.
jwmbishop is offline   Reply With Quote
Unread 08-18-2014, 12:58 PM   #8
HighandLow
Stay Frosty...
HighandLow's Avatar
2010 JK Wrangler
Originally Posted by jwmbishop
if you straighten the steering wheel - doesn't that make it a handlebar?
har
2010 Rubicon, Auto, Stone White, 3"Synergy Coils, MetalCloak TB's and CA's, 35" Grabbers, 17" AEV Pintlers, ORF, PSC, JCR, PIAA, AEV, TeraFlex equipped...
HighandLow is online now   Reply With Quote
Unread 08-18-2014, 01:08 PM   #9
Rubedog302
Handle better?
