stock rubicon "How High" - JeepForum.com
post #1 of 9 Old 08-16-2017, 02:22 AM Thread Starter
Pappywolf
2014 JK Wrangler
OK s, stock Rubicon, 34 inch BFGs, No rubbing for now. Question, How high should I go and not get crazy. Thanks No rock crawling, camping fishing, hunting. Nothing crazy, This is my everyday vehicle.
Pappywolf is offline
post #2 of 9 Old 08-16-2017, 07:42 AM
cranbiz
If you want to lift it, go with a 2.5" lift. This will give you some more clearance and the look and also not cost lost of money to fix geometry problems that a taller lift will cause.
I recommend the Teraflex spring lift with an adjustable front track bar.
06 KJ
12 JK,2.5" Teraflex lift,Bilstein 5100's,BFG KO2's P305/65R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #3 of 9 Old 08-16-2017, 09:52 AM
SLADE
Keep it mild. Use just enough suspension lift to get into around a 10" travel shock. Most of the 10" travel shocks will need 1"-2" bump stops (some a little more) so you will need around 2" of lift (2.5 would be fine).
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #4 of 9 Old 08-17-2017, 03:35 AM Thread Starter
Pappywolf
2014 JK Wrangler
Thanks gentlemen, I will look in to that today.
post #5 of 9 Old 08-17-2017, 05:50 AM
Bill123
2016 JK Wrangler
Just to reaffirm, a 2.5" lift would be perfect. I have the Teraflex kit and it's exactly what I needed. It's quality stuff and easy to install. I don't rock crawl either, just alot of trips to and from the beach.
2016 Wrangler Unlimited
2.5" Teraflex Lift
305/70-17 Toyo Open Country AT2
Fuel Lethal Wheels
Bill123 is offline
post #6 of 9 Old 08-18-2017, 02:02 AM
Bigbob
Bigbob's Avatar
Are those the 10:50/34 tires? Or are they the metric? What back space are the wheels? I'm looking to do similar.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #7 of 9 Old 08-18-2017, 05:59 AM
K9kodi
Get whatever lift and height you want. its your money, if you want tall go tall, if you want squatting go squatty. If you do a lot of hunting, and I'm not sure what kind, I usually have a lot of weight with me. Tree stand, hunting box, cooler, guns or bows, sometimes a buddy and his gear, d look into heavier duty springs.
K9kodi is offline
post #8 of 9 Old 08-19-2017, 10:48 AM
Hudson3
My experience... I started with a 2.5" budget boost... to get it to drive "right" I ended up doing everything a 3.5" lift requires. So, in the end, I added 3.5" springs/shocks.
So, for your uses, I would level out the front with some 3/4" spacers and call it a day.
2013 JKR 6spd 3.5" MCGCARB 35"KM2s 5.13's 1310DLs armored PSC hydro Zeon8k.
Hudson3 is online now
post #9 of 9 Old 08-19-2017, 01:55 PM
hossler
I put 34s(285 75 17) on my stock jku. And it was fine until i hit the trails then it had a very minor rubbing issue in the rear. Then i install a 2" front 1" rear teraflex coil spacer lift. Its perfect for what i use my jeep for
Sent from my SAMSUNG-SM-G928A using Tapatalk
hossler is offline
