AS STOCK AS POSSIBLE WITH 35's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > AS STOCK AS POSSIBLE WITH 35's?
Only 2 Days left to win $3,800 Jeep Parts!Rough Country Jeep Suspension Deals at Rockridge 4WD!Nitro Gears now available in stock at JeepHut
Unread Yesterday, 01:52 AM   #1
ElkdogNC
OK, 2009 JK Sahara 2dr, bone stock except for a rough country bumper bob, and spacers. want to keep my stock wheels, and want to trim the fenders, sooo:
What springs?
What shocks?
looking for real advice.
Thanks!
ElkdogNC is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 08:30 AM   #2
Denbag
I have 2012 2dr sport. got a set of 18/59 springs off a 4dr rubi (got about 1" lift out of them) the rest is completely stock besides front 10A bumper. I run 35x12.5r15 with 3.75BS wheels. If i hit a bump real hard the kiss the front fenders real quick. If you want to trim your fenders you should have more than enough room.
I don't like wheel spacers but lot of people run them. i think 1.5" is what you would need if you want to run a 12" wide tire.
Denbag is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 08:40 AM   #3
SLADE
To keep it as stock as possible, your going to have to rely on flat fenders, trimming, and/or a Body lift to increase tire clearance instead of bump stops(lift).
Your limited on your choice of low lift height coils for a 2 door so unless you want 2" or more lift, you may want to use coil spacers or factory 4 door coils to keep the ride height low.
Flat flares increase tire clearance more in the front than the rear, so you'll still need some bump stop/lift even with flat flares.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is online now   Reply With Quote Quick reply to this message
Unread Yesterday, 09:21 AM   #4
98tjsahara
1.5" RK springs on 33's. Would have plenty of room to articulate with 35" tires if I cut the fenders. But I'm not ready to open up the can of worms that comes with 35s.
Sold the 98 TJ Sahara. Buying another Jeep soon!
98tjsahara is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 09:49 AM   #5
ElkdogNC
Attachment 1850721
So what is the "can of worms?" i see plenty of posts on here that for DD and soft trail type wheeling 35" tires are handled well by the JK.
Do you say different?
Unread Yesterday, 09:52 AM   #6
222Doc
222Doc's Avatar
gears.< seems you have not looked at this enough yet
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 11:29 AM   #7
ElkdogNC
so do you mean in regards to transmission shift points, or differential? as a DD 90% of the time, i do plan on a tuner for speedo & shift points...
i really don't think it will ever be wheeled hard enough for a re-gear...
Unread Yesterday, 11:34 AM   #8
SLADE
Gears are not just a benefit offroad. They are just as important if not more of a benefit on road.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
Unread Yesterday, 01:30 PM   #9
98tjsahara
If I were going to run 35" tires, and feel good about doing it, I would want at minimum:
New rear tire carrier to support 35" spare. Reinforced front d30.
Re-gear front/rear with Truetrac's while I'm at it. Cut stock fenders or buy aftermarket
That's in addition to the things I already have:
Rock sliders
RK 1.5" springs
Bilstein 5100 shocks
Proper bump stops f/r
Steering stabilizer flip
Recovery gear
AEV Procal
And some things I would still want:
Currie Anti-rock
OBA setup
Bumpers
Winch
Control arms
Drive shafts
Track bars
Skids
Ect ect...
My Jeep currently does very well on and off road with 33's and I didn't feel the need for a re-gear/lockers ($2,000+), reinforced d30 ($500 with labor?), or rear tire carrier ($700-$1,500). Not to mention all the other items I want.
