Stock JK Tie Rod diameter? - JeepForum.com
post #1 of 4 Old 09-03-2013, 02:05 PM Thread Starter
matrix311
Does anyone know off hand what the outside diameter of the stock tie rod is for a 2008 JKUR? I've looked around on google and forum search and i'm only finding OD for aftermarket tie rods. I'm having a custom made 7075 t6 aluminum tie rod made for our JK and it's 1.5" diameter. Just trying to figure out if the steering stabilizer clamp I have will fit on this new tie rod. I replaced the steering stabilizer last year and the dealership gave me a new heavy duty tie rod clamp for the stabilizer and a new larger OE stabilizer as they redesigned them all vs what I had on there from the factory.
If anyone could post up the size of the OEM tie rod outside diameter I would appreciate it. My Jeep is not with me so i cannot measure it and I need to figure out if I need to order a new tie rod clamp for the stabilizer today for the new 1.5" tie rod.
Thanks
Eric
Eric - *'92 White YJ, 4.5" custom Deaver springs, 35" MTRs, Tera-Low 4:1, CAI, Rear 8.8, Chromo D30, 4.88s, locked front/rear, full cage and front/rear tube fenders.
*'08 Silver Rubicon JKU 2.5" lift, 5.13's and 35's
matrix311 is offline
post #2 of 4 Old 09-03-2013, 03:46 PM Thread Starter
matrix311
looks like it's 1 3/8" for anyone that cares or needs this info.
post #3 of 4 Old 09-03-2013, 04:00 PM
JIMBOX
Like matrix says-it's 1-3/8"--or close 1.385"
Course, thats at 82F/4200' altitude/humidity 26%--
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #4 of 4 Old 09-10-2013, 05:46 PM
Maertz
2009 JK Wrangler
Thanks
Eric
yes you will need a new bracket as others have showed. I had made a 1-1/2 od by 1/4 wall tie rod and bent it to **** on my first trip out... Hopefully your aluminum one is solid that may help
Maertz is offline
