Stock height track bar options? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Stock height track bar options?
Jeep Grand Cherokee Mirror - Side ViewJeep Grand Cherokee Header PanelTJ 5.25" Speaker Adapters - NalinMFG
Unread 05-23-2014, 08:09 AM   #1
johnsoninc86
What adjustable track bars will work on a stock height JK Unlimited? I'd prefer the JKS Track bar as I like the bushing design over the JJ style of the other bars, but I'm getting mixed information on whether it will fit a stock height JK. Any other aftermarket options out there for stock height track bar?
Thanks!
98 XJ Sport
07 JKU Sahara
johnsoninc86 is offline   Reply With Quote
Unread 05-23-2014, 08:58 AM   #2
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
If you check I believe the JKS will work on a stock JK, and if you life, then it will adjust for a modest amount of lift. Other than the stock TB is a bit flimsy, why change it?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 05-23-2014, 01:16 PM   #3
SLADE
Check out Metalcloak's Trackbars. They are made to clear the differential cover and accommodate stock exhaust.
2013 Wrangler JK
2012 Wrangler JKU
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is online now   Reply With Quote
Unread 05-23-2014, 02:17 PM   #4
johnsoninc86
Thanks guys. I called on the JKS and they confirmed that their track bar will NOT work with a stock height JK, they said the bar does not thread down short enough. I also contacted MetalCloak and their bar does NOT fit a stock height JK. They said they need minimum 2.5" of lift for their bar to fit. Looks like Synergy is going to be the winner. I called them and they confirmed that their bar DOES fit stock height JK's. I've got one on order with Northridge along with their grade 8 bolt kit.
My track bar is currently toast at 87,000 miles, and I plan on lifting this thing in a year or so, so I figured it would be best to go ahead and upgrade now to an adjustable. Hopefully get rid of the DW too...
Thanks again.
98 XJ Sport
07 JKU Sahara
Unread 05-25-2014, 08:58 AM   #5
SoK66
1976 CJ5
Good choice. When you lift you'll be wise to consider Synergy.
SoK66 is offline   Reply With Quote
