Still confuesed...surely someone knows (audio install) - JeepForum.com
post #1 of 10 Old 03-22-2011, 11:13 AM Thread Starter
nismosis
OK, so here is the scoop. I have an 08 sahara with the Infinity sound system. I have already replaced my factory sound bar speakers. I have a new Pioneer head unit arriving shortly as well as a new mono-amp and subwoofer. So in the end I would like to have actively working; the factory front speakers (tweeters included), my new sound bar speakers(rear) as well as the aftermarket subwoofer. I will be removing the factory subwoofer and factory infinity amp, running the fronts(tweeters included) and rear off of the pioneer head unit. The mono-amp is for the sub. That is all pretty straight forward.
My confuesion starts here. How do I wire the tweets to the new deck? Do I splice them in with the fronts to the new deck? Or will I blow them by doing this? Im not sure if they have a built in crossover, or if I will need one. If that is the case I would most likely buy a new component kit for the front; which I do not want to do. What are my options?
Also, what is the situation on the power, on/off accessory power, and ground for the new deck. I have done some research on lots of forums and what I am gathering is that there is no accessory power from the factory wiring. Could someone clarify this for me? There is a power and ground in the factory wires though correct?
At the end of the day I would like to have my speakers directly wired to my pioneer deck (no amps), and the power source, on/off power source, and ground coming from the factory radio wires. Is this possible?
Sorry for my giant rant, Im just trying to be clear as mud The sub and sub amp are not an issue, its just these darn tweeters, and the power sources that are giving me trouble.
Thank you
nismosis is offline
post #2 of 10 Old 03-22-2011, 11:17 AM
Charles
2017 WK
How does the factory headunit split it? Are you using a wiring harness?
2017 TrailHawk Hemi, Everything but the TV's.
Charles is offline
post #3 of 10 Old 03-22-2011, 11:33 AM Thread Starter
nismosis
Im not sure how it is hooked up via the factory. I will probably run new speaker wires to each speaker, so I can bypass all the infinity system. I have not had it apart yet. I dont want to use any aftermarket harnessess. I want to just use the wires that come off the back of the pioneer deck and go right to the desired speaker/power/ground. Make sense? I guess you could say, hard wired right to the deck. Im assuming colors on the deck will be different than colors in the jeep.They always have been in my past experiences. The only wires I plan on reusing are the factory power(s) and ground, if they are even present in the factory harness.
nismosis is offline
post #4 of 10 Old 03-22-2011, 03:43 PM
bobrio
2009 JK Wrangler
in order to run the tweeters and midrange off the same channel you will need a CROSSOVER to split the frequencies so the highs go to the tweeters and the mids go to the midrange speaker.
bobrio is offline
post #5 of 10 Old 03-22-2011, 03:54 PM
Charles
2017 WK
If you buy a harness it will do the splitting for you. The Tweeters probably have an inline capacitor to get rid of the mid and bass...i.e. a crossover. You're not doing anything by running wire to every speaker other than causing yourself a lot of work. You'll need a capacitor anyway. If you want to get really crazy you can buy an electronic crossover...
Charles is offline
post #6 of 10 Old 03-22-2011, 04:01 PM
RubiNoob
2010 JK Wrangler
The factory infiniti amp has output for tweeters, mids, rear, and subwoofer
RubiNoob is offline
post #7 of 10 Old 03-22-2011, 04:12 PM
Charles
2017 WK
If that's true then you only have to put your amp where that amp is and just use those wires, coming off of your own cross over. Or, new wires coming off of the cross over.
You can feed the tweets with the same wire as front speakers but that would be halfassing it. If you do that then you'll need the cap to get rid of the freq's that the tweeter doesn't need.
Based on the fact that you want all new wiring you will want to go with a crossover.
Charles is offline
post #8 of 10 Old 03-22-2011, 04:21 PM
RubiNoob
2010 JK Wrangler
The factory amp adjusts the levels for each frequency based on the volume. This is controlled via canbus.
Best advice for you:
1. Get a wiring harness for your radio.
2. Purchase Component System for Front
3. Run new speaker wire to HU
4. Run RCA from Sub-Out to mono amp
Good Luck.
RubiNoob is offline
post #9 of 10 Old 03-22-2011, 07:22 PM
Prot
Prot's Avatar
2014 JK Wrangler
See my signature. It works. The front components installed in the factory locations including the tweeters. My crossovers are in the ends of the dash.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #10 of 10 Old 03-22-2011, 11:46 PM
marmotmb
I will try to help you out here. this might be a long post sorry
you should easily be able to wire the tweets in with the front speakers, do some searching on speaker wiring and OHM ratings, you want to ensure your wiring keeps the OHM rating that acceptable to the deck. I think in paralell is the way to go. You will need to install a capacitor inline on the tweet speaker wire. this takes away all the lows and only lets through the highs. there are different caps for different levels. IE will only let 10,000 and above past, or 9,000 and above past for example. my experiance in the past was this is trial and error, every vehicle and deck combo and tweet combo sound different. but a few types and try.
I think what you are curious about for your mono amp is the remote or a signal to turn it on with the key. your new deck will have a "remote" wire. this goes to the amp.
go to any car stereo place and buy a wiring harness and deck mount kit. this wiring harness will plug right into your factory deck wiring and tell your what colour is what...IE power, switched Power, front left, rear right etc.... but.... my advice is do not use the factory ground wire and in a perfect world don't use the factory power either. run your own power wire to the battery and find a really good ground and ground it there from the deck. the switched power is not critical this is just telling the deck to turn on and off, there is no amp load on this wire.
Pro Comp - Hypertech Programmer / 2.5" Teraflex coil lift & 1" M.O.R.E Body Lift / 315/75R16 Pro Comp Mt. Extremes / 16" x 8" Pro Comp Series 52 (Black) / Pro Comp steering stabalizer / Air Raid Cold air intake / Ace Enginnering and Fab Front stubby with bull bar / OR Fab Rear tire carrier / 2 Blitz Jerry Can / HI lift jack / Cherry Bomb 2.5" Exhaust and Custom Tail pipe / KC Daylighter 6" 130 Watt with Driving lense / Shifter boot trim ring bolt mod / Rear Bumper gap mod / Mirror drill hole mod
marmotmb is offline
audio components , deck , speakers , tweeter
Trying to put together wiring diagram before audio install... Mol JK Wrangler Technical Forum 11 03-09-2011 08:17 AM
Slowly but surely Exl2392 TJ Wrangler Technical Forum 1 12-15-2010 06:32 PM
8.8 factory spring perches bolt right up to the YJ? Surely not.... Matt Graham YJ Wrangler Technical Forum 32 01-02-2010 06:57 PM
Xfer Linkage - Surely I'm not the first to have this happen. BadHammers JK Wrangler Technical Forum 1 07-01-2009 07:22 PM
Slowly but surely the mods are coming... fireguy553 TJ Wrangler Technical Forum 33 04-06-2008 05:21 PM
