Stepping on the gas & hearing a noise - Page 2 - JeepForum.com
post #16 of 17 Old 12-08-2013, 01:06 PM
GlennH
I have the same problem. I have a full MBRP Cat Back Exhuast and its not that heat shield at the crosspipe or muffler. When driving into 4th gear the jeeps rpm curve goes from 3,000ish down to 1700 and then back up, during this the jeep is going about 60km/h and then speed increases to 65-68km/h and is about 21-2200rpm. Its a rattle or grinding sound when on the accelerator but when you let off the gas it goes away.
any such luck or new ideas?
GlennH is offline
post #17 of 17 Old 12-08-2013, 01:16 PM
pineaur
My '13 JK makes a noise similar to what the OP posted. It DOES sound like a heat shield rattle to me. Going to have to climb back there in the engine compartment and see if it's a poor weld or a crappy design. Noticed it with only about 3k miles on it. Mine is a six speed manual.
pineaur is offline
Stepping up to a long arm kit....... rdcox23 TJ Wrangler Technical Forum 1 01-25-2010 08:45 PM
I'm hearing an odd noise. Please help. pdangerp TJ Wrangler Technical Forum 4 01-16-2010 05:54 PM
Hearing a bad grinding/churning noise Mitch_B TJ Wrangler Technical Forum 14 10-28-2009 11:53 PM
Confused about a noise I'm hearing The Fuzz YJ Wrangler Technical Forum 7 11-26-2004 10:09 PM
Question about a noise I am hearing... AJ0 TJ Wrangler Technical Forum 7 11-07-2004 07:17 PM
