Stepping on the gas & hearing a noise - JeepForum.com
post #1 of 17 Old 03-16-2012, 09:56 AM Thread Starter
ToniF303
When I step on the gas (after the Jeep is warmed up) I hear a metal like noise. But the longer I step on the gas, the noise goes away. Until l stop the car and then again, I hear the noise when I step on the gas. This has been going on for about 10,000 miles, and it's at 62,000 miles now. 2007 JK 4 door
Any ideas???
ToniF303
ToniF303 is offline
post #2 of 17 Old 03-16-2012, 11:42 AM
LIJeepJC
Well, considering the mileage you have experienced this, it's not very serious or you would have experienced a breakdown at some point. It's hard to diagnose "noise". Especially since I can't hear it from where I am. I would think that it's no big deal, and that I wouldn't worry about it.
LIJeepJC is offline
post #3 of 17 Old 03-16-2012, 12:06 PM
ronjenx
ronjenx's Avatar
Any ideas???
Manual? Or auto?
The noise goes away as the Jeep picks up speed?
Could be pinging from expecting too much in too high a gear.
If that's the case, you need to look into it.
Could be as simple as some tin rattling underneath, too.
ronjenx is offline
post #4 of 17 Old 03-16-2012, 02:08 PM
LIJeepJC
Originally Posted by ronjenx
Manual? Or auto?
I was thinking pinging too, but shouldn't the computer compensate?
LIJeepJC is offline
post #5 of 17 Old 03-16-2012, 02:27 PM
propped1
Its the heat shield above the muffler... The welds suck. They break. Costs me $100 at the dealer to find that out. Happened twice. I just bent it back myself and saved the money the second time. The metal sound is the shield vibrating on the exhaust when you accel. Same thing happened to me. Just bend it back. If you have a welder you can more permanently fix it. I dont.
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
post #6 of 17 Old 03-16-2012, 02:48 PM
paul olllllllo
Location: royal oak michigan (hometown of DR. JACK KEVORKIAN)
Would a high temp silicone kind of "glue" it in place?
2008 Flame Red "Captain America" Unlimited.
paul olllllllo is offline
post #7 of 17 Old 03-16-2012, 03:07 PM
propped1
never tried... let me know how it works out
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
post #8 of 17 Old 03-16-2012, 03:07 PM
nyrangersfan19
Not necessarily the heat shield. My JK has AWFUL pinging.
OP: Is the noise happening at a certain RPM EACH time? If so, it might be some exhaust resonance, like the heat shield mentioned above. If not, it could be pinging. (spark knock)
nyrangersfan19 is offline
post #9 of 17 Old 03-16-2012, 03:09 PM
LIJeepJC
If its the catalyst than not sure if the glue can stand that heat...
LIJeepJC is offline
post #10 of 17 Old 03-16-2012, 04:13 PM
ronjenx
ronjenx's Avatar
The computer's ability to reduce pinging has its limits.
ronjenx is offline
post #11 of 17 Old 03-18-2012, 01:06 PM Thread Starter
ToniF303
The Jeep is an Auto. Thanks for your ideas.
ToniF303
ToniF303 is offline
post #12 of 17 Old 03-18-2012, 01:07 PM Thread Starter
ToniF303
Wow... thanks for the idea. Could be the problem. We'll check it out.
ToniF303
ToniF303 is offline
post #13 of 17 Old 03-18-2012, 01:10 PM Thread Starter
ToniF303
I just seem to hear the noise when I first step on the gas. I'm starting to hear it more often when I'm going faster and step on the gas. That's a girl answer, huh?!!
ToniF303
ToniF303 is offline
post #14 of 17 Old 03-19-2012, 05:42 AM
nyrangersfan19
Yeah, that sounds like spark knock. Try running Premium for a couple tanks and see if that helps. If it goes away with the premium, then you know thats the problem. I have no idea how to fix it.
post #15 of 17 Old 03-19-2012, 02:41 PM Thread Starter
ToniF303
Sounds like maybe the easier try. I'll try that first.
PS - LOVE the Rangers, too!
ToniF303
ToniF303 is offline
Stepping up to a long arm kit....... rdcox23 TJ Wrangler Technical Forum 1 01-25-2010 07:45 PM
I'm hearing an odd noise. Please help. pdangerp TJ Wrangler Technical Forum 4 01-16-2010 04:54 PM
Hearing a bad grinding/churning noise Mitch_B TJ Wrangler Technical Forum 14 10-28-2009 10:53 PM
Confused about a noise I'm hearing The Fuzz YJ Wrangler Technical Forum 7 11-26-2004 09:09 PM
Question about a noise I am hearing... AJ0 TJ Wrangler Technical Forum 7 11-07-2004 06:17 PM
