Steering Stabilizer Torque - JeepForum.com
post #1 of 3 Old 09-20-2012, 03:51 PM Thread Starter
MKWrangler
I just changed my Steering Stabilizer with a Rancho unit. My torque specs say the bolt and nut need to be torqued to 50 ft. lb. While torquing the nut I noticed the bushing started to come out so I stopped. Now the bolt and nut are pretty darn tight but still not at 50 ft. lbs. My question is do they really need to be that tight, it seems too tight and will put to much pressure on the bushings?
MKWrangler is offline
post #2 of 3 Old 09-20-2012, 08:09 PM
Coolcatracing
The bushing should have a metal sleeve inside it to bottom out on the bolt so it can't deflect the bushing too far. If yours does not have the sleeve then you need to get one because it will never be correct and the bolt will loosen over time.
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
Coolcatracing is offline
post #3 of 3 Old 09-20-2012, 09:35 PM Thread Starter
MKWrangler
It has the metal sleeve in it.
Rancho part# for universal steering stabilizer mount for hd steering??? BigDeaner YJ Wrangler Technical Forum 3 10-26-2011 09:35 PM
Question about Steering Stabilizer after HD steering install. Hellbound13 JK Wrangler Technical Forum 2 07-14-2009 09:29 PM
RC steering stabilizer bolt/nut torque autotechboy111 TJ Wrangler Technical Forum 3 12-07-2008 11:18 AM
Rock Krawler HD steering + steering stabilizer Giviner TJ Wrangler Technical Forum 1 05-03-2008 07:19 PM
Steering stabilizer attachment to steering link Bill87GT TJ Wrangler Technical Forum 8 09-08-2007 08:59 PM
