Steering Stabilizer - Page 2 - JeepForum.com
post #16 of 78 Old 12-08-2009, 09:10 AM
DeepSky
Originally Posted by thebobjeep View Post
Which ball joints are you planning on going with, have you considered a zerks, or a modified grease-able? Mine are wearing, and the driver side needs replacing soon. I refuse to go back to stock.
I was thinking about trying these out:
Jeep® 07-09 Wrangler & Wrangler Unlimited JK Ball Joint Kit :: Jeep Steering :: AtoZ Fabrication
Have you tried removing the bolts and looking for a wallowed out hole? Mine seemed perfect when tested, when the bolts were loosened, you could see the movement and it was obvious when removed. Once this was resolved, my shimmy went away.
Not yet. Maybe I'll check it out this weekend as well. To anyone who has had washers welded to fill the holes, how much did it cost you?
I'm pretty sure I mildly damaged my tie rod, so I was planning on a poly rod and hi steer kit.
This might have a lot to do with it. Before I started just adjusting my toe myself, I had a shop set my toe-in and suddenly my Jeep pulled HARD towards the grade. I found out they had set my toe-in to a little over 1/4". After I put it back to around 1/8" the pull wasn't bad anymore.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #17 of 78 Old 12-08-2009, 09:41 AM
Hellbound13
Wouldn't a heavy front bumper put MORE stress on the front suspension?
As far as ball joints these are very expensive but are supposed to be the last ball joints you will ever need. They will be available in about three weeks..
Dynatrac ProSteer Ball Joints
Hellbound13 is offline
post #18 of 78 Old 12-08-2009, 09:48 AM
thebobjeep
Do you have a price on these? Earlier this year several companies where working on them, but I haven't seen any come out.
thebobjeep is offline
post #19 of 78 Old 12-08-2009, 09:50 AM
Hellbound13
Ive heard around $500 for the set of four.
post #20 of 78 Old 12-08-2009, 02:09 PM
DeepSky
I saw those a few weeks ago on here, but the price is just insane. I'm going to give the AtoZ Fab ones a shot first. At least they're greasable.
DeepSky is offline
post #21 of 78 Old 12-08-2009, 02:32 PM
ncb
The Dynatrac ball joints in the pictures have zerks.
ncb is offline
post #22 of 78 Old 12-08-2009, 04:14 PM
DeepSky
I'll tell you what, if Dynatrac says that their ball joints will permanently fix my shimmy or my money back I'll fork over the $500 bucks.
DeepSky is offline
post #23 of 78 Old 12-08-2009, 06:04 PM
Hellbound13
The A to Z are made by Crown right? Are you positive they will fit the JK? I was told there are no greaseable ball joints for the JK yet.
post #24 of 78 Old 12-08-2009, 06:51 PM
DeepSky
Yeah Crown (I actually just saw that myself). According to their site it's a Jeep® 07-09 Wrangler & Wrangler Unlimited JK Ball Joint Kit.
DeepSky is offline
post #25 of 78 Old 12-08-2009, 07:02 PM
Hellbound13
Well get and let me know if they are better than stock!
Although judging by that pic it looks like its going to be hard to grease that bottom zerk with the u joint in place.
post #26 of 78 Old 12-08-2009, 09:53 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
You can get right-angle zerk fittings and point them towards the rear!
All this talk about ball-joints makes me hope mine go bad sooner rather than later, so I can get warrranty replacement before big tires!
Jim
JLC08JK is offline
post #27 of 78 Old 12-08-2009, 11:24 PM
Hellbound13
Well I just checked. Those Crown joints are the same as OEM and do not come with zerk fittings. The picture shown are TJ ball joints that do come with the zerks, the JK ones do not.
Looks like Im shelling out for the Prosteer when they come out.
post #28 of 78 Old 12-08-2009, 11:34 PM
premo
Originally Posted by OCBob View Post
Good evening all. I added a Rancho Steering Stabilizer at the beginning of the summer along with many other mods (see below) After many tweaks I still occassionally have the shimmy. Does anyone think dual steering stabilizers would help the problem? If so, what kind are you happy with. THX
things to check:
track bar
drag link
tie rod
ball joints
slop/looseness in steering box and shaft to firewall
bushings on all 4 control arms
steering knucle
wheel bearings
all of these things should have ZERO slop of movement. adding another stabilizer will simply mask the problem, not fix it. good luck!
-Scottish proverb
premo is offline
post #29 of 78 Old 12-21-2009, 10:07 AM Thread Starter
OCBob
2009 JK Wrangler
Thanks for all the ideas. So far no luck. Good thing I have a friend as a mechanic and it has not cost me my whole arm yet. He is equally frustrated. All the info I could find was mixed on the steering stablizers, so I have elected to hold off. Since so many of us are having the same issue, I hope one of us finds a solution soon. It appears some of you have been even more aggressive trying to fix this with no real solution. This is very frustrating and a pain in the neck! I did not buy a jeep to avoid the potholes in on the highway...... Scary thing is my kids are getting used to it.
09 JK Sahara, LS V8, 6L80Auto, 5.13 Yukon, Dana 44, 3" Teraflex Lift, Bilstein Shocks, JKS Trackbar, AEV Steer Kit w/Bilstein Stabilizer,MT 17x9 Lock II, Nitto Grappler 37X1250, EGS Grab Handles
OCBob is offline
post #30 of 78 Old 12-21-2009, 12:49 PM
premo
did you remove and physically/visually inspect the bushings on the trackbar and control arms? you might find your problem there.
-Scottish proverb
premo is offline
Question about Steering Stabilizer after HD steering install. Hellbound13 JK Wrangler Technical Forum 2 07-14-2009 10:29 PM
Rock Krawler HD steering + steering stabilizer Giviner TJ Wrangler Technical Forum 1 05-03-2008 08:19 PM
Steering stabilizer attachment to steering link Bill87GT TJ Wrangler Technical Forum 8 09-08-2007 09:59 PM
Steering Stabilizer CJmadison TJ Wrangler Technical Forum 9 03-30-2007 05:51 PM
steering stabilizer ionakana YJ Wrangler Technical Forum 7 09-18-2006 05:08 PM
