Steering stabalizer 2011 jk - Page 2 - JeepForum.com
post #16 of 32 Old 06-25-2013, 07:15 AM Thread Starter
Droptop306
2011 JK Wrangler
Yes I got home and removed the ss and bracket. I found that the Dow screw that holds the bracket is bent. I have the new high mount coming tomorrow with all new brackets. How far on the tie rod does the bracket go? I drove it home without the. Ss and seen very little difference. Is there anything else that could cause me to not be able to turn the wheel. It seems that I can force it straight again when it happens but would hate for it to happen at high speed. Luckily I was pulling into garage each time at work. not unless the jeep is trying to tell me NO don't go in there. Lol
Droptop306 is offline
post #17 of 32 Old 06-25-2013, 07:49 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Most likely whenever the clamp was damaged - so was the stabilizer and now is short on travel so cant make both left and right extremes - and when suspension travels (like turning into a driveway and going through bump omn one side and rebound on the other) it needs more that just ain't there!
The stock clamp is okay - until you hang it or bend it after which it will be very unpredictable. You are headed in the right direction replacing. Keep in mind some of that unpredictability and coming loose is from the gouges put on the tie rod - make sure to address that with either a mill file or replacement with a chromemoly tie - replacing the tie is a good idea - if you dragged the clamp you may easily have bent the tie. Will still work but once bent it gets "spongy" on the obstacles..
When you put it all together attach the tie rod end last. Center the steering, pull the stabilizer all the way out (full extension) and mark the tie rod where the eye is. Then push it all the way in (full compression) and mark the tie rod again. Then simply mount the clamp with the stabilizer eye bolt dead center between the two marks. Leaving the marks aids in future checks to make sure nothing has moved.
Does your high mount kit come with the tie end clamp? Many use the stock turned over. Link to the clamp I prefer - it does not hang harshly on rocks and the clamp is centered to the eye bolt - not offset like stock design.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #18 of 32 Old 06-25-2013, 09:12 AM Thread Starter
Droptop306
2011 JK Wrangler
It comes with new brackets. They look like u bolts with clamp and nuts. I ordered the Superlift 92135 kit for mine. I will have to start looking into the new tie rod. I guess best bet would be so that at same time as ball joints. I hope this corrects the issue. I really like the jeep just seems between the leaks and this a 35k rig should treat me better
post #19 of 32 Old 06-25-2013, 09:41 AM Thread Starter
Droptop306
2011 JK Wrangler
Ok. I am taking your word and going to order a new tie rod bar. Is synergy a good brand? I found one for the Jk that comes with new tie rod ends as well. If so I will go ahead and order it. Main question. Is my jeep safe to drive until it comes without steering stabilizer. I would rather put all on at once. Also is the tie rod bar and ends a easy application. I am good with working on vehicles as long as I have some insight how to do it. The jeep and lifted vehicles is new to me but learning quickly. I am more of a muscle car guy with a 08 mustang. By the way thanks for all the help
post #20 of 32 Old 06-26-2013, 03:29 AM
HOKIES2010
2011 JK Wrangler
Synergy makes great stuff in my experience. I have their HD mounts, brackets and axles sleeves. The Jeep is fine to drive without the SS until you get it fixed. Like someone said you should notice the bump steer. If you replace the SS, an OEM works just fine. I have heavy 37s and I have no issues with a stock SS.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #21 of 32 Old 06-26-2013, 07:31 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
I agree with Hokie (don't let that get out!).
I have synergy stuff - even their cm tie. No problems with it so far. I used the one that took the stock ends - but the oem ends went out right after (hammering on the can opener in Hot Springs) and I replaced with heavy duties.
post #22 of 32 Old 06-26-2013, 12:21 PM
HOKIES2010
2011 JK Wrangler
I won't tell, might put it into my sig block though
My Build
post #23 of 32 Old 06-27-2013, 02:47 AM Thread Starter
Droptop306
2011 JK Wrangler
Got one more question. Since the steering locked up for that brief second I have noticed a clicking feeling in the steering wheel when it turn the wheel to either side. I feel it just as I start to turn the wheel even at highway speeds if I just jerk side to side. Is this normal or did I bust something else
post #24 of 32 Old 07-09-2013, 11:24 AM Thread Starter
Droptop306
2011 JK Wrangler
tie rod bar
I finally got the tie rod bar in the mail. I ordered the synergy with heavy duty tie rod ends. How do you install same? Do I need another front end alignment? Off road estimates 250 to install it.
post #25 of 32 Old 07-09-2013, 02:25 PM
1222
RIP John
1222's Avatar
If you are handy at all with tools then save yourself a ton of money and do it yourself. Itís not hard at all and Iím sure there is a YouTube or two floating around that will guide you through it visually.
1222 is offline
post #26 of 32 Old 07-09-2013, 04:29 PM
Spaf
2011 JK Wrangler
I just installed the Synergy TR yesterday and again today. For me nothing mechanical is ever easy but I keep plugging away. Drove the jeep maybe thirty miles today on various roads, sans steering stabilizer, and everything felt right. Waiting on the backordered track bar now. Good luck with yours and ask away if you have questions.
Yellow Jeep Club #54
"Que scais-je?"
Spaf is offline
post #27 of 32 Old 07-10-2013, 06:06 AM Thread Starter
Droptop306
2011 JK Wrangler
since i am going through all of this what ball joints should i replace the factory ones with. i was looking at the Alloy Heavy Duty upper and lower..
post #28 of 32 Old 07-10-2013, 01:22 PM
1222
RIP John
1222's Avatar
Synergy seems to be the most popular. If youíre installing them yourself be sure you have the proper tools, the uppers can give you grief on install if not.
1222 is offline
post #29 of 32 Old 07-11-2013, 04:12 AM Thread Starter
Droptop306
2011 JK Wrangler
ok I purchased the Alloy USA upper and lower ball joints. So now I think this will complete the entire steering upgrade. Hope this fixes everything. Goes to the shop on Monday. Cant wait to see this tab.... Keep everyone posted.
post #30 of 32 Old 07-11-2013, 06:41 AM
brianjw
Have you read some of the reviews on here on those alloy USA ball joints?
I think I'd see if I could send them back and buy the synergy ball joints myself.
brianjw is offline
