Steering is loose on the highway after suspension lift - Page 2 - JeepForum.com
post #16 of 32 Old 09-11-2013, 04:16 PM
Vin
How about tire pressure? What are you running?
Vin is offline
post #17 of 32 Old 09-11-2013, 04:17 PM
JIMBOX
YUP, the alignment shop has no way of adjusting CASTER in a stock suspension jeep
Originally Posted by leogeo View Post
Thanks everyone for your quick response- the alignment shop told me that's the best they can get it
I was thinking the correction brackets- but not before I bring it to another shop for another look
I use Adj Lower Control Arms and my caster is just above 5+
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #18 of 32 Old 09-11-2013, 04:36 PM
mello
You cam use cam bolts to get caster in check and it is way cheaper than arms. This is not a good solution if regular off roading is in your future however. This would only be a good fix for a daily driver that very seldom gets off road.
mello is offline
post #19 of 32 Old 09-11-2013, 09:03 PM
Panhead5
2009 JK Wrangler
Put on the geometry correction brackets.When you install a lift it changes (shortens) the caster angle up to about a degree and the steering will be flighty..If you install the brackets you have a choice of 3 holes .Mine are in the center ones and the caster is at about 5 degrees .Problem solved .
Panhead5 is offline
post #20 of 32 Old 09-11-2013, 11:31 PM
suicideking
Subscribing to see what fixes it. Mine is similar -- I've had an alignment and steering wheel straightened.
I also have the traction control light going off, mostly when I'm using the brakes, but have had it go on when cornering, etc.
suicideking is offline
post #21 of 32 Old 09-12-2013, 07:28 AM
JoeCitizen
Probably the lose nut behind the steering wheel.
Sorry, couldn't help myself.
JoeCitizen is offline
post #22 of 32 Old 09-12-2013, 08:16 AM
HighandLow
HighandLow's Avatar
2010 JK Wrangler
Not to hijack, and maybe this question will help the OP if he decides to go this way.
How was the install? I've got mine sitting in the garage waiting for a day off.
2010 Rubicon, Auto, Stone White, 3.5"Synergy Coils, DL and TR, MetalCloak TB's and CA's Fr/Rr, 37"Coopers 18" Ions , Adams 1310's, G2 5.13 gears, Synergy Sleeves and Gussets, ORF, PSC, JCR, PIAA,Rancho equipped...
HighandLow is offline
post #23 of 32 Old 09-12-2013, 09:07 AM
HOKIES2010
2011 JK Wrangler
This is why I can't see using the stock CAs
My Build
Couldn't have done it without
HOKIES2010 is offline
post #24 of 32 Old 09-12-2013, 09:14 AM
JIMBOX
On a JK/JKU after a 2" to 3" lift and ESPECIALLY running 35' tires--
The measured distance between bolt centers on the FRONT LCAs NEEDS to be at least 23" and however you attain the figureis up toyou
Mine is 23.25" and that keeps the caster/pinion angle manageable-
Nothing is simple anymore, so DO HOMEWORK-
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #25 of 32 Old 09-12-2013, 07:17 PM
69rs
2011 JK Wrangler
Park on a flat surface. Loosen the control arm bolts. Push down on bumper to make sure it settles. Retorque bolts to spec. If the Jeep was on a lift when the springs were installed and the bolts were tightened on the lift, this will fix hour problem.
2011 JK Sport
jim
69rs is offline
post #26 of 32 Old 09-12-2013, 07:27 PM
ncb
OP is running light which means the front end is up at least 3.5" from stock. Adjust the caster or it will suck.
ncb is offline
post #27 of 32 Old 09-13-2013, 01:23 PM Thread Starter
leogeo
Great! Thanks all... Will order the geo brackets. Seems that will correct the caster for the tires at least. There are many variables with the suspension and many things to consider when running large tires. This time for me this one is not as easy as my other JKU back in 07. I will update some results
leogeo is offline
post #28 of 32 Old 09-16-2013, 12:53 PM
roadrat
First check the tire pressure, then alignment.
roadrat is offline
post #29 of 32 Old 09-16-2013, 12:55 PM
roadrat
I wonder if a steering stabilizer would be beneficial here?
roadrat is offline
post #30 of 32 Old 09-16-2013, 10:22 PM
suicideking
I just picked up my Jeep from the mod shop today and they fixed this for me: The steering wheel was off center, fixed with Procal and centering the steering wheel. Also the steering was loose, fixed by tightening a loose bolt on the drag link.
