Steering is loose on the highway after suspension lift - JeepForum.com
post #1 of 32 Old 09-11-2013, 12:00 PM Thread Starter
leogeo
Hi, has anyone experienced having loose steering at highway speed after installing the AEV 2 1/2" lift?
leogeo is offline
post #2 of 32 Old 09-11-2013, 12:05 PM
Filthy-Beast
loose or flighty?
did you adjust toe in?
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #3 of 32 Old 09-11-2013, 12:19 PM Thread Starter
leogeo
Sorry hit send before typing all the info...
JKU 10A with the AEV 2 1/2" lift and 35x12.5 MTR's
Feels very light in the front at highway speeds with the hardtop on and the 35" spare. I do have the end caps off the front bumper too.
Softop and topless it's fine with no issues at all. It drives and rides great!
I'm thinking we need more weight on the front end to balance the hardtop and spare. Not sure on this one- any input would be great.. Thanks
Oh here is a pic
leogeo is offline
post #4 of 32 Old 09-11-2013, 12:20 PM Thread Starter
leogeo
Yes toe in adjusted and its all aligned- steering wheel is front and center
leogeo is offline
post #5 of 32 Old 09-11-2013, 12:24 PM
HOKIES2010
2011 JK Wrangler
Sounds like a great excuse for a wench
My Build
Couldn't have done it without
HOKIES2010 is offline
post #6 of 32 Old 09-11-2013, 12:27 PM
bogleparsons
X2 on the winch ^^ nice Jeep!
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #7 of 32 Old 09-11-2013, 12:32 PM
HOKIES2010
2011 JK Wrangler
lol or a winch. Guess a wench sitting on the bumper would have the same result. Damn typos
My Build
post #8 of 32 Old 09-11-2013, 01:28 PM
nikjeep
Had the same problem. The guy who did a 2" lift on mine had to align is twice before it got back to "stock" feeling. I had to death with the death wobble for a day. Sounds like alignment to me.
nikjeep is offline
post #9 of 32 Old 09-11-2013, 01:30 PM
nikjeep
Oh sorry, just read that you had it aligned. Nevermind.
nikjeep is offline
post #10 of 32 Old 09-11-2013, 01:51 PM
ncb
Did you adjust the caster?
ncb is offline
post #11 of 32 Old 09-11-2013, 02:44 PM
HOKIES2010
2011 JK Wrangler
Just because it got alignment doesn't mean it was done right. First shop I took mine too had be all kinds of jacked up. Also filled my tires all the way up, made the Jeep floaty as hell. 2nd shop got it right on the money.
My Build
post #12 of 32 Old 09-11-2013, 03:17 PM
JIMBOX
Just as ncb says-CASTER-?
Every jeeps a little different, but with your 2.5" (?) lift you've probably lost some of your + caster and are WAY LOW (3/4)-
With a 2dr and 35" tires (toein is probably still off) you need at least 5 + caster, otherwise the jeep goes where it damn well pleases-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #13 of 32 Old 09-11-2013, 03:40 PM
jeremylj1972
Just got my 2.5" AEV lift on but added the caster correction brackets...no alignment yet and 315s drives great and steering is centered. Feels as good as stock did.
2013 JK 2Dr
jeremylj1972 is offline
post #14 of 32 Old 09-11-2013, 04:50 PM Thread Starter
leogeo
Thanks everyone for your quick response- the alignment shop told me that's the best they can get it
I was thinking the correction brackets- but not before I bring it to another shop for another look
leogeo is offline
post #15 of 32 Old 09-11-2013, 05:15 PM
HappyTrails
Registered Voter w/ID
HappyTrails's Avatar
Check your tire pressure. Too inflated may cause this feeling.
When my tires were shipped, they were pumped up to about 60psi. But man, they sure could bounce when the rolled off the UPS truck. LOL!
Best bet way to determine your proper tire pressure (for your individual Jeep considering weight, etc) is to put some sidewalk chalk across the tread and then drive it. Then check the wear pattern. Inflate/deflate as necessary to get the chalk to wear all the way across the tire tread.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
