Steering Gear Adjustment - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Steering Gear Adjustment
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 04-01-2010, 03:19 PM   #1
premo
1992 XJ Cherokee
incase anyone was wondering, here's how to adjust your steering gear box:
STEERING GEAR
NOTE: Adjusting the steering gear in the vehicle is not recommended. Remove gear from the vehicle and drain the fluid. Then mount gear in a vise to perform adjustments.
OVER-CENTER
1. Rotate the stub shaft with Socket 8343 from stop to stop and count the number of turns.
2. Center the stub shaft by rotating it from the stop 1/2 of the total amount of turns.
3. Place torque wrench and Socket 8343 in a vertical position on the stub shaft. Rotate the wrench 45 degrees each side of the center and record the highest rotational torque in this range. This is the Over-Center Rotating Torque.
NOTE: The stub shaft must rotate smoothly without sticking or binding.
4. Rotate the stub shaft between 90° and 180° to the left of center and record the left off-center preload. Repeat this to the right of center and record the right off-center preload. The average of these two recorded readings is the Preload Rotating Torque.
5. The Over-Center Rotating Torque should be 0.45-0.80 N·m (4-7 in. lbs.) higher than the Preload Rotating Torque.
6. If an adjustment to the Over-Center Rotating Torque is necessary, first loosen the adjuster lock nut. Then turn the pitman shaft adjuster screw back (COUNTERCLOCKWISE) until fully extended, then turn back in (CLOCKWISE) one full turn.
7. Remeasure Over-Center Rotating Torque. If necessary turn the adjuster screw and repeat measurement until correct Over-Center Rotating Torque is reached.
NOTE: To increase the Over-Center Rotating Torque turn the screw CLOCKWISE.
8. Prevent the adjuster screw from turning while tightening adjuster lock nut. Tighten the adjuster lock nut to 37-52 N·m (27-38 ft. lbs.).
-Scottish proverb
premo is offline   Reply With Quote
Unread 04-01-2010, 03:59 PM   #2
Hellbound13
Can't get simpler than that.
Hellbound13 is offline   Reply With Quote
Unread 04-01-2010, 06:22 PM   #3
Prot
Gold Member
Prot's Avatar
Why would I need to adjust my steering gear, especially since it says it is not recommended?
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, Goodyear Duratrac 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Front Rancho 9000 shocks, Rear Bilstein 5100 series shocks, 5.13 gears, Kenwood DNX9990HD, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650
Prot is offline   Reply With Quote
Unread 04-01-2010, 06:37 PM   #4
ronjenx
ronjenx's Avatar
It's just not recommended to adjust it while it is still installed. There is no way to measure the results when still installed.
ronjenx is online now   Reply With Quote
Unread 04-01-2010, 06:38 PM   #5
premo
1992 XJ Cherokee
its not recommended to do it on the rig....or if you dont know what you're doing. lol i have to as mine's WAY out of adjustment. it's really not that hard to do though..
-Scottish proverb
Unread 04-01-2010, 06:41 PM   #6
Hellbound13
I have heard that several people have adjusted it just 1/8 turn while still on their rig with no issues.
Unread 04-04-2010, 01:22 AM   #7
JLC08JK
What was I thinking?
JLC08JK's Avatar
Is Socket 8343 a Mopar part number or an off the shelf part-store item?
Thanks for the write-up, it will come in usefull at some point
Jim
Jim's Jeep; THE OBSESSION LIVES ON!
Jim's JK D44 Rear Axle Build
99% of Your JK Questions will be Answered Here
JK F.A.Q./WILL IT RUB and Popular Threads
Protect Our Rights to Freedom and the Environment
Visit the EnviroBeat
JLC08JK is offline   Reply With Quote
Unread 06-13-2012, 08:38 PM   #8
WATERMAN31
Junior Member
2009 JK Wrangler
Nice write up. Will this adjustment help with "wondering"? My JK wonders all over the road and I'm not sure if its the Gear Box or my Lift or the Tires and Alignment? Not sure where to start. Any help is greatly appreciated.
E:
Time Flies when your having Rum!
WATERMAN31 is offline   Reply With Quote
Unread 06-13-2012, 08:40 PM   #9
ncb
Plasti Dip yourself!
ncb's Avatar
2009 JK Wrangler
E:
Did you correct the caster after after the lift?
ncb is online now   Reply With Quote
Unread 06-13-2012, 08:43 PM   #10
WATERMAN31
Junior Member
2009 JK Wrangler
I had a 4 wheel alignment and they said it was with in spects. Is there a better adjustment for camber than factory? This thing really wonders around the highway.
Unread 06-14-2012, 06:58 AM   #11
TurtleSlinger
2009 JK Wrangler
4 wheel alignment?
I thought with wranglers you can only do 2 wheel alignment...just saying....
I have had to do minor adjustments to my steering gear while on vehicle. I have had to adjust 1/8 turns clockwise twice. No issues. If anything has made the steering feel better.
Current stable:
09 JK Rubicon 35's and 5" lift - modded
09 WK Limited 5.7 Hemi OVERLAND - stock
07 MB AMG E63 "My 11 sec sedan" - modded
11 HD NightRod Special - modded
TurtleSlinger is offline   Reply With Quote
Unread 06-14-2012, 07:50 AM   #12
ronjenx
ronjenx's Avatar
Originally Posted by TurtleSlinger View Post
4 wheel alignment?
Most alignment shops check the alignment on the rear axle, too, even on vehicles with solid axles. Something can be bent, and checking all the angles will reveal that.
It's funny you said the adjustment made the steering feel better.
I just posted in another thread on this subject that the adjustment isn't a matter of just making it feel better. It's a matter of obtaining the correct pre-load.
Unread 06-14-2012, 08:05 AM   #13
WATERMAN31
Junior Member
2009 JK Wrangler
Yup, 4 wheel alignment, I have adjustable upper & lower control arms. They, the dealer, said all were in specs except one was just out of spec but shouldn't be a problem?!
Question, Pre Load, will that take out the "play" in the steering? It really wonders at like 55 to 70 mph.
Unread 06-14-2012, 08:39 AM   #14
ronjenx
ronjenx's Avatar
If the pre-load is too loose, there will be play in the steering box.
That's not the only possible cause, though.
Unread 06-14-2012, 08:41 AM   #15
JkSteveNB
2009 JK Wrangler
4 wheel alignment?
Although most don't have any adjustments in the rear it's good practice to check the specs on the rear as well. Because although it isent adjustable it needs to be factored in. If you have some toe in or out in the rear this can cause dog tracking. So a thrust alingment is done using the rear axle as a starting point for adjusting the front. This in turn gives you little to no pull!
JkSteveNB is offline   Reply With Quote
