Steering Bolt Mod For Jeep Wrangler JK - JeepForum.com
post #1 of 2 Old 01-25-2013, 10:35 AM Thread Starter
Morris4x4Center
Morris 4x4 Center
Morris4x4Center's Avatar
1987 YJ Wrangler
Installing bigger tires on your stock wheels or maybe on a set of New wheels? While making a full locking turn your Jeeps front sway bar, frame rail, and possibly lower control arms may get some light rubbing. This happens when the backspacing is not correctly formulated. Unfortunately many Jeepers don’t know this until their new wheels and new tires are fully mounted and installed on the Jeep. Jeepers might run into this issue after installing a small lift, especially if an adjustable front track bar wasn’t included with the kit. Now, the obvious fix would be to buy new wheels with correct back spacing or install a set of Wheel Spacers to help reduce your back spacing. But if the rubbing is very minor, you may find it just as easy to adjust out your steer stops. This modification will cause you to loose a little bit of turning radius. Using a couple washers and a wrench, you can easy fix your light rubbing issue in minutes.
Read More On Our Morris 4x4 Center Blog
If you feel you might be rubbing too much, we have Wheels Spacers to help offset your backspacing.
[B]
Jeep Parts and Jeep Accessories
(954) 941-7807
We offer Price Match, Military, Law Enforcement & Special Forum Discounting
Plus Free Shipping on Orders Over $75*!
Please PM us for any questions.
Morris4x4Center is offline
post #2 of 2 Old 01-28-2013, 04:50 PM
brady1929
thanks
brady1929 is offline
