Steering adjustment post lift & wheeling - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Steering adjustment post lift & wheeling
20 Ton Press Brake DIY Builder Kit @ Swag Off RoadRough Country Lift Kits and Parts!Father's Day & Moving Day Sale!
Unread 10-12-2009, 09:56 PM   #1
robsbluerub
So here is the chronology of events:
Lift JK 3.5 inches and add 35s
Take great pains to center steering, computer good for 3000 miles
Go on wheeling trip, have great time
After trip, steering wheel is off about 10 deg, lights on the dash
I recentered the steering, didn't find anything bent or broken. Still threw codes for a bit then the lights went away. It drives perfect and I'm not worried but just curious. Can it just be "settling?"
2007 JK 2dr Rubicon, 3" Black Diamond Lift, 35" KM2s, M/T Classic IIs, Rancho shocks, Mopar bumpers, 8000 lb winch, Ace rock sliders, Skid Row engine/oil pan skid, evap skid, Tom Woods driveshafts, Riddler diff covers, Superlift steering stabilizer relo, rear adjustable upper control arms, chromoly rear shafts.
robsbluerub is offline   Reply With Quote
Unread 10-13-2009, 01:43 PM   #2
DeepSky
Possibly. I have experienced this once before. After a few start ups and drives of the Jeep everything was back to normal. You could always try the disconnect battery for x amount of minutes to restart the computer trick if you're worried about it.
If everything is fine now I really would not be concerned.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(My Build Details)
DeepSky is offline   Reply With Quote
Unread 10-13-2009, 01:45 PM   #3
alaskanthunder
I thought you restarted the computer by touching the battery cable together (disconnected of course). Which discharged the system.
2007 JK 2-dr X | Steel Blue | 4.10 Auto D44
alaskanthunder is offline   Reply With Quote
Unread 10-13-2009, 03:12 PM   #4
Jodyblip
i would be more concerned of how it got back 10 degrees out than i would the light.
i would check all the steering bolts sounds potentially dangerous
Jodyblip is offline   Reply With Quote
Unread 10-13-2009, 03:16 PM   #5
DeepSky
A long time ago I had my steering wheel get uncentered after wheeling before. The adjuster bolts didn't feel loose but they weren't exactly tight either. I just recentered and everything has been fine since.
Not saying there isn't a potentially dangerous problem, but I wouldn't rule out the possibility that you just knocked your front end really good on a rock or something that caused the wheel to be uncentered.
Unread 10-13-2009, 03:17 PM   #6
DBA2GO
Happy Trails!
DBA2GO's Avatar
I don't think so. Just give is some time (e.g. a few minutes).
One foot in the grave & one foot on the gas pedal!!
DBA2GO is offline   Reply With Quote
Unread 10-13-2009, 05:22 PM   #7
robsbluerub
Prudent to tighten everything. Will do that this weekend.
Touching the cables? sounds like voodoo.
Unread 10-13-2009, 06:45 PM   #8
alaskanthunder
I can't remember where I read that. Maybe the dealer said that to me.
But all the same. Taking the negative off for a few minutes has the same result, clearing the ECU.
Unread 10-13-2009, 07:06 PM   #9
bubba2u
2009 JK Wrangler
if your steering wheel is off i would think either your coupler on the drag link is loose or you bent your drag link.
bubba2u is offline   Reply With Quote
Unread 10-13-2009, 07:59 PM   #10
RockyClymer
RockyClymer's Avatar
I have had this problem twice before (about 10 degrees off to clockwise direction - meaning the drag link was too short) - the steering is off-center after some hard rock crawling that really worked the suspension and steering. I have triple checked and had two 4x4 centers check the front end - nothing is bent, broken or out of place and all bolts, nuts, etc seem to be tight...I did re-torque the track bar up to 130 lbft after find one end at only about 90 lbft - and thus far it is staying where it should...go figure, I can't.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is online now   Reply With Quote
