Steering 2013 JK - JeepForum.com
post #1 of 9 Old 07-02-2014, 10:06 AM Thread Starter
S1L3NT_WH33L3R
2005 WK
Steering 2013 JK
Have a '13 JK sport on a Teraflex 2.5" lift. Death wobble is getting bad so I'm looking at getting an entire front end done. Any recommendations on high steerkits? Looking at the Teraflex High Steer kit. Looks to be most complete.
'05 WK Limited, QD-II, 5.7L HEMI, Volant Cold Air Intake, Aries Taillight Guards, Rola Roof Rack, Cobra CB, Firestik Antennas, Magnaflow Performance Exhaust, OME HD lift, 285/70-17 GY Duratracs, Spidertrax Spacers, Superchips Programmer, Steel Armadillo Super Sliders
~Jeep makes it HEMI shakes it~Ain't Nothing Humble about that HEMI Rumble~
S1L3NT_WH33L3R is offline
post #2 of 9 Old 07-02-2014, 11:12 AM
222Doc
222Doc's Avatar
high steer will not fix DW. Before you start the replace the front end thing. You need to find out why it is.
1# Tires balanced correctly.
2# track bar issues. The factory track bar has some very poorly made bushings. The bolts tend to crush the inner sleeve. This leads to looseness. It can be missed even doing the steering test. One way i found to tell if its FUBAR. try to remove the bolts if they pull out the bushing sleeve is ok. If the bolt seems stuck. The sleeve has deformed. just righting it more ends up just making it worse.
3# if everything in the suspension is ok. what is your caster angle?
222Doc is offline
post #3 of 9 Old 07-02-2014, 11:33 AM Thread Starter
S1L3NT_WH33L3R
2005 WK
I'm replacing everything. Track bar, drag link, tie rod, bushings, and stabilizer. That was the plan from the beginning
post #4 of 9 Old 07-02-2014, 12:44 PM
BlackNMWK
2008 WK
If that's all you going to replace you still need to check your ball joints.
BlackNMWK is offline
post #5 of 9 Old 07-02-2014, 10:04 PM
motoguy1251
Synergy parts are a great system to run. I know a lot of us run them including me.
motoguy1251 is offline
post #6 of 9 Old 07-02-2014, 11:33 PM
mtnbiker995
2009 JK Wrangler
What do you need a stabilizer for?
mtnbiker995 is offline
post #7 of 9 Old 07-05-2014, 03:08 PM
HOKIES2010
2011 JK Wrangler
On the trackbar make sure the holes are not jacked up. If the trackbar bolts weren't tight enough they can distort the hole.
And the stock steering stabilizer works fine. Don't waste your money on a fancy one unless you get really want something shinny up front.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #8 of 9 Old 07-06-2014, 10:03 AM Thread Starter
S1L3NT_WH33L3R
2005 WK
Well I bent the track bar a while back. Ever since then it's thrown off everything up front which is why I'm just gonna replace it all
post #9 of 9 Old 07-06-2014, 02:21 PM
mtnbiker995
2009 JK Wrangler
Bent the track bar?! Holy **** lol
