Stealership insisting on using regular oil not synthetic - Page 2 - JeepForum.com
post #16 of 40 Old 12-03-2010, 06:38 AM
Warlord2
I just use dino oil......If it was a sports car engine or a any engine that actually cranks out some ponnies then I run a blend or pure synthetic. These 3.8L have been around forever and dont need any special treatment, they really arnt even made for it. A lot of performance engines like those in the 350z, G35, Vets, etc....run at a much higher compression and the oil is more important for cooling.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #17 of 40 Old 12-03-2010, 06:46 AM
owtdorz
2009 JK Wrangler
Here we go:
Syn and Dino oil change intervals ARE THE SAME.
I put syn in the day it came off the delivery truck.
I change it every 3k.
I never lose/burn ANY oil between oil changes.
Waiting until 7 or 10k is not wise since the manual states that it is no longer than 6k.
If you do wait until 10k to do oil changes and you have an engine problem under warranty they can and probaly will ask for maintanence records. If they are at 10k intervals you WILL be denied warranty.
I work at a dealer and I have seen it happen.
You can make your own decision on when and what but I am not that big of a penny pincher.
$36k plus investment is not worth skimping IMO.
'09 Detonator Yellow 4dr Rubi, Bestop Element doors, Rugged Ridge XHD w/stinger, Warn 9.5ti, 3.5 Rock Krawler, Woods driveshafts, Hella 500 aux lights, 35x12.5x17 BFG KM2<< THEY SUCK
owtdorz is offline
post #18 of 40 Old 12-03-2010, 06:56 AM
badgerking
I'm not changing my oil, ever. I tell her I am but I just spend the cash on a packet of air fresheners and a box of tissues , she thinks an oil change costs 6 bucks. I figure if I do this long enough then the engine will sieze and then I can put a Hemi in it, it's not like the wife knows that an engine shouldn't cost $15k
badgerking is offline
post #19 of 40 Old 12-03-2010, 07:03 AM
Joevacs
2010 JK Wrangler
That right there has to be the strangest post I've seen yet....
2010 Rubicon, 4" lift, Currie control arms and trackbar, 40" Procomp MTR
Joevacs is offline
post #20 of 40 Old 12-03-2010, 07:05 AM
paul84043
Originally Posted by owtdorz View Post
Here we go:
I didn't say don't change you oil until 10k, I said wait until 10k to switch to syn to give your engine a chance to break in.
And you're wrong, Synthetic oils allow you to go much longer between changes. My VW Jetta TDI uses one of the highest grades of synthetic oils available and the factory interval is 10k. I do 5k anyway, and I don't believe in the 3k\3month thing either.
I have actually done extensive research on oils as part of my job, but I'm not going to hijack this thread and go into a dissertation.
You can't believe everything you read in the manual either. Manufacturers want your vehicle to last the length of your warranty + 1 day and no longer. They want you buying vehicles, there's no money in building Zambonis.
paul84043 is offline
post #21 of 40 Old 12-03-2010, 07:21 AM
Joevacs
2010 JK Wrangler
what's a "Zambonis" ?
Joevacs is offline
post #22 of 40 Old 12-03-2010, 07:29 AM
jstrubberg
2009 JK Wrangler
If you change you oil at the recommended intervals (and no, 3k is NOT the recommended interval!), 90% of the advantage of synthetic is removed. I change mine at 5k just because it keeps the math easy.
jstrubberg is offline
post #23 of 40 Old 12-03-2010, 07:36 AM
owtdorz
2009 JK Wrangler
Now a TDI is a European Diesel. The Libby and Grand Cherokee Diesel have 10k intervals.
The SRT model vehicles that require syn state the oil changes are to be done 3 to 6k.
owtdorz is offline
post #24 of 40 Old 12-03-2010, 07:46 AM
prjohnson
I don't care what anyone says. I use Mobil 1 & a good filter. Change it every 3k miles, change air every 6k. Oil comes out looking fresh & clean & jeep runs awesome at 99k miles. Replaced RMS at 70k. My Jeep is paid for, so I pay the extra cost to make sure things are kept in good running order. I'm in the business, so it's cheap for me. Anything over 5k feels way too long for an oil change.
prjohnson is offline
post #25 of 40 Old 12-03-2010, 07:50 AM
jstrubberg
2009 JK Wrangler
It's your Jeep.
post #26 of 40 Old 12-03-2010, 09:20 AM
TJ06WRANGLER
A long time friend of mine did the same thing. He changed the filter once a year, and added oil as needed. When he sold the car it had over 300,000 miles on it. Of course it was the venerable slant six, almost nothing will kill those engines. Not that I recommend it, but it worked for him.
TJ06WRANGLER is offline
post #27 of 40 Old 12-03-2010, 09:27 AM
paul84043
Originally Posted by jstrubberg View Post
It's your Jeep.
Exactly! If it makes you happy, it can't be that bad.....right?
The Zambonie has gone down in history as the quintessential example of someone making a quality product and basically working themselves right out of a job.
The Zamboni is what they use to clean and resurface Ice skating rinks. Mr Zamboni invented his version of this machine and they sold great until there were no more ice rinks that needed them....
Then they never broke down and basically live (relatively) forever because of the light duty.
Oops.
Modern corporations work around this by employing "Down Designers". Basically engineers who's job it is to design parts to fail at a certain point. They work under the shroud of "cost effective manufacturing" but in reality, they are assuring a failure in a reasonable amount of time.
post #28 of 40 Old 12-03-2010, 09:55 AM
Crasher
Changing oil every 3000 or 6000 miles benefits the owners peace of mind more than it benefits the engine. Oil analysis will tell when to change oil. Synthetic oils tend to run to 15,000 miles before a change is recommended. Dino oils need replacing sooner, but I haven't seen any research that indicates when. The 3000 mile change interval is a carry over from the 1950s when oils and engines weren't what they are today. In the end, change oil when you just can't sleep at nights. That will be sooner than the engine needs it, but at least you won't be so tired.
Sorry for the hijack. Under normal use, dino oil is fine. Under extreme conditions syn might be better.
2005 LJ, 112" wb, RJ60's, ARB lockers, Fox Coil overs, 40" Creepies
Crasher is offline
post #29 of 40 Old 12-03-2010, 10:24 AM
jstrubberg
2009 JK Wrangler
I do 5k oil changes because I worry about particulates and my oil filter more than I worry about the oil.
post #30 of 40 Old 12-03-2010, 11:35 AM
BRICKTOP2
Unhingd PigFeedng Gangstr
BRICKTOP2's Avatar
Yeah. Because that is such a viable long term business plan, right? I'd say it's relatively safe to say that the percentage of factual information in an owner's manual is pretty darn high. Maybe even higher than a thread on Jeepforum.com.
You might find an error every once in a while, but when it comes to maintenance intervals, I'd say sticking to their recommendation is a safe bet.
"Tightening the nut behind the wheel is the most cost effective way to improve the performance of any vehicle."
JK Build Thread
TJ Tub Trailer
BRICKTOP2 is offline
synthetic oil vs. regular oil chappy84 TJ Wrangler Technical Forum 89 07-27-2009 04:33 PM
Synthetic or Regular???? WarrenNJ TJ Wrangler Technical Forum 62 06-22-2006 01:59 AM
Regular to Synthetic oil MissionMan TJ Wrangler Technical Forum 5 02-22-2006 02:25 PM
Synthetic or regular Oil???? CaptainJim TJ Wrangler Technical Forum 5 02-29-2004 03:54 AM
Synthetic vs. Regular Oil Lucky_4x4 TJ Wrangler Technical Forum 6 12-30-2002 10:28 AM
