Stealership insisting on using regular oil not synthetic - JeepForum.com
post #1 of 40 Old 12-02-2010, 04:59 PM Thread Starter
herculz
2010 JK Wrangler
Been reading about oils that everyone use, has anyone kept the dealership oil as their default for oil changes?
Will it help my JK to switch to synthetic or half and half?
had first oil change at 1k, now i'm close to 4k and want to stick to one oil from this point on. Dealership says i don't need synthetic, makes no difference as long as i change the oil as it should be done.
Thanks
herculz is offline
post #2 of 40 Old 12-02-2010, 05:03 PM
tjkj2002
2002 KJ Liberty
Thanks
They would be correct.
tjkj2002 is offline
post #3 of 40 Old 12-02-2010, 05:05 PM
Unlimitedlou
Search the forum. There are soooooooooooo many different opinions. I like synthetics.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #4 of 40 Old 12-02-2010, 05:08 PM
No_Return
Here we go again...
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
No_Return is offline
post #5 of 40 Old 12-02-2010, 05:37 PM
armedsks
2009 JK Wrangler
You dont have to run synthetic. Todays Dino oil is much better than it was 20+ years ago. The best thing you can do is change it!!.. Most Dino oils can go 4-5k between oil changes no problem. Dealers and jiffy lube place's still push the 3k OCI because its extra income.
My wifes 08 liberty we use dino at 3k OCI since we get free lifetime oil/filter changes. I run Synthetic oil in my 09 JK and do my changes 6-9k miles OCI's I buy what ever walmart has on sale or the auto parts store(q-horse power, pennzoil platinum, mobil 1 etc. etc. Make sure to use a quality oil filter/ (mopar, motorcraft purolator etc.) Dont use Fram orange cans if you plan to go more than 3k OCI'S.
To me it makes more since to run synthetic and change oil 6-9K than running Dino oil. I can buy name brand synthetic and a good oil filter and change it myself for under 30$
I have the lifetime power train warranty and i plan on keeping this until the US outlaws fossil fuels!!!
armedsks is offline
post #6 of 40 Old 12-02-2010, 05:42 PM
paul84043
I wouldn't worry about it yet as your vehicle is not completely broken in yet anyway, but at/around the 10k mark or so, I would personally request a synthetic blend. I have never had a dealer dictate to me what to put in, it's supposed to go the other way.
The only thing you buy with a synthetic is a little extra protection in the off chance that you do encounter seriously punishing conditions for your engine such as crawling in Moab in the dead of summer, or extreme towing.
The other thing you buy is a tiny buffer zone in the event of some type of catastropic engine failure, say, your oil pump failing, or filter popping off.
If you live in a perfect world, then go with the regular organic, it's fine for everyday use, commuting, and mall crawling. I like the peace of mind that a blend gives me.
There is really nothing you can do in one of these to seriously warrant a full synthetic.
Oh, and what he said ^^^^ about a quality filter...I agree completely!
paul84043 is offline
post #7 of 40 Old 12-02-2010, 06:03 PM
TJ06WRANGLER
The dealership cannot tell you what to use for oil or filters. They do have to meet manufacturer specs for warranty compliance. Went to court on that one and won.
Personally I don't care for synthetics, I prefer fossil oil. The one thing I can tell you though is use the same oil at all times. I have seen engines use a lot of oil by using what's on sale all the time. I sold parts for 30 years and every time I convinced someone to use the same oil all the time their consumption went down.
Of course someone is going to say that is all garbage. I just know what I know and will adhere to it for all time for myself. Also I have never lost an engine because of oil, I always lost them from over revving or over loading them.
TJ06WRANGLER is offline
post #8 of 40 Old 12-02-2010, 06:05 PM
Doctor7474
It doesn't matter.
Doctor7474 is offline
post #9 of 40 Old 12-02-2010, 06:08 PM
slimtim454
2010 JK Wrangler
So manual calls for oil change every 6k miles. That seems too long to go, should I be changing oil before 6k?
slimtim454 is offline
post #10 of 40 Old 12-02-2010, 06:18 PM
tennistom1
2009 JK Wrangler
On my 2006 TJ, I asked an experienced Jeep tech at a dealership when I could switch to synthetic and he answered conservatively at 30,000 to make sure the rings seat properly. Like I said, that's a conservative answer. Many new vehicles come with synthetic when new but there are many different engines with different engineering build tolerances. I'd stick with what the manufacturer recommends to avoid warranty issues.
2009 JK Rubicon 4-Door
2006 TJ Rubicon Unlimited
tennistom1 is offline
post #11 of 40 Old 12-02-2010, 06:21 PM
allibaster
You should use whatever is specified in the user manual, which is non-synthetic. You'd just be wasting your money otherwise.
The same could be said regarding fuel octane rating.
'13 JKU 10th Anniversary
allibaster is offline
post #12 of 40 Old 12-02-2010, 06:24 PM
tennistom1
2009 JK Wrangler
The on-board computer tells you when to change oil. A notification will light up on the gage cluster that tells you when to change oil based on your driving habits and conditions.
post #13 of 40 Old 12-02-2010, 07:20 PM
rirrgang
They don't want you to wait for 10k oil changes like people that use syn do. I've got 59k on ours. Started syn at 5k and now change every 10k. No problem, no issues.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #14 of 40 Old 12-02-2010, 10:01 PM Thread Starter
herculz
2010 JK Wrangler
considering i've had my jk maybe a month and haven't even received my plates yet and im at 3700 miles, most highway miles, minimum of 100 per day so looking to see what options i have.
herculz is offline
post #15 of 40 Old 12-03-2010, 04:41 AM
paul84043
With those kind of highway miles, you're going to be fine with an organic oil....
That's some serious driving you're doing!!
You've still got a ways to go before you even need to think about it, but you are checking your oil level aren't you???? (with all the oil consumption issues we've seen around here..)
synthetic oil vs. regular oil chappy84 TJ Wrangler Technical Forum 89 07-27-2009 04:33 PM
Synthetic or Regular???? WarrenNJ TJ Wrangler Technical Forum 62 06-22-2006 01:59 AM
Regular to Synthetic oil MissionMan TJ Wrangler Technical Forum 5 02-22-2006 02:25 PM
Synthetic or regular Oil???? CaptainJim TJ Wrangler Technical Forum 5 02-29-2004 03:54 AM
Synthetic vs. Regular Oil Lucky_4x4 TJ Wrangler Technical Forum 6 12-30-2002 10:28 AM
