Starting in Second - JeepForum.com
post #1 of 11 Old 03-22-2007, 06:37 PM Thread Starter
EagerJeeper
Starting in Second
How many of you start in 2nd gear from a stand still?
The 06 Wrangler did it effortlessly, but my JK does not do it as well as I thought it would. Or at least it seems to prefer a 1st gear start. It is an Unlimited Rubi with stock tires. I finally decided to use 1st unless I'm still moving or heading down hill.
EagerJeeper is offline
post #2 of 11 Old 03-22-2007, 06:40 PM
DirtyJeepJK
DirtyJeepJK's Avatar
The 06 Wrangler did it effortlessly but my JK does not do it as well as I thought it would. Or at least it seems to prefer a 1st gear start. It is an Unlimited Rubi with stock tires. I finally decided to use 1st unless Im still moving or heading down hill.
i usually use 2nd in a low geared vehicle, but i would have to agree with you that the JK seems to take off smoother in 1st. maybe once i have a few thousand miles on it i'll go back to the 2nd gear start.
DirtyJeepJK is offline
post #3 of 11 Old 03-22-2007, 07:08 PM
MARider
I am ignorant here...why start in 2nd?
Thanks,
Dave
MARider is offline
post #4 of 11 Old 03-22-2007, 07:24 PM Thread Starter
EagerJeeper
Many utility type 4 wheel drive vehicles have a "Granny Gear" for first, and a second gear that is comparable to a first gear in "normal" vehicles.
The "Granny Gear" is useful for low speed pulling or starting out with a very heavy load. It usually won't even get you through an intersection. Under normal driving though most vehicles with the "Granny Gear" start off in 2nd gear.
I would say that the JK's 1st gear is not quite as low as some other's, and I find myself using it almost always.
post #5 of 11 Old 03-23-2007, 05:01 AM
300bhp/ton
1995 XJ Cherokee
I think starting off in 1st gear is actually pretty standard and should be considered "normal".
Tyre size, internal gear ratios and of course the final drive ratio will all affect this. As will the PCM and throttle control module (I assume the JK is fly-by-wire??). And how the engine is tuned (where it makes it's power).
If it doesn't like pulling away in 2nd, simple - use 1st
Ex Jeep owner. Currently lots of Land Rovers....
300bhp/ton is offline
post #6 of 11 Old 03-23-2007, 08:39 AM
JeF4y
If I'm rolling at all I'll start in 2nd, but otherwise I'm in 1st.
07 Wrangler Unlimted Sahara 4dr 4x4
05 Liberty CRD 4x4 (gone!!! 3/23/07) - When Jeep gives you lemons....
JeF4y is offline
post #7 of 11 Old 03-23-2007, 05:42 PM
redrom01
JCOB-4-LIFE
redrom01's Avatar
I have to agree that it isnt so easy to start in second.
-Jeep History-
1992 XJ - '00 till '04 - RIP (thanks alot dave)
1995 XJ - '03 till '07 - Sold to the HUB
______o00o
/__l_l_,\____\,__
l_---l_l__l----[ ]llllll[ ]
._(o)_)__(o)_)--o-)_)__
-Current Jeep-
2007 JK Rubi (Steel Blue)
Searching for an MJ
|¯¯l,[___],
l---L--OlllllllO¬
=~~~==oo==
()_) ()_)--<>-)_)
redrom01 is offline
post #8 of 11 Old 03-23-2007, 07:34 PM
Prot
Prot's Avatar
2014 JK Wrangler
Do you have 4.10 gears?
Prot is offline
post #9 of 11 Old 03-23-2007, 08:04 PM
STANSUSKI
2nd gear almost always
2007 Unlimited X base model black,6spd.4.10,front and rear mats.Added deep tint softop windows,30%tint front and15%rear doors.Mopar hitch and 4-way wiring harness.Optional 17" wheels/tires.COMING SOON 2009 RUBICON UNLIMITED PURCHASED 04/17/2009
STANSUSKI is offline
post #10 of 11 Old 03-23-2007, 08:32 PM Thread Starter
EagerJeeper
Yes, it's a Rubicon.
post #11 of 11 Old 03-25-2007, 06:49 PM
2ksaharawhite
2ksaharawhite's Avatar
I can finally post my op on this thread! I drove my JK Ruby (4.10) for the first time last night, and found it to be very comfortable starting in 2nd. Of course I'm not heavy on the gas, like most people here in the NJ suburbs. Starting in 1st is fine too, it gives for a quicker take off, but who really needs that in a Wrangler? I also noticed it doesn't get through a light before needing to shift to 2nd. I prefer to take it easy, and enjoy the ride! Let the Honda import 'tuners' wait their turn in line!
2007 JK Rubicon 6spd - Red Rock
2ksaharawhite is offline
Not Starting YJCrawler1 YJ Wrangler Technical Forum 1 11-13-2009 02:43 PM
yj not starting??? maine jeepster YJ Wrangler Technical Forum 10 01-27-2008 09:31 PM
Not starting LlamaJeep YJ Wrangler Technical Forum 0 01-27-2008 10:06 AM
Not always starting RedLion YJ Wrangler Technical Forum 11 07-20-2007 08:13 AM
not starting help slimdog21 YJ Wrangler Technical Forum 4 08-24-2005 03:49 PM
