Starting problem: crazy clicking under fusebox - JeepForum.com
post #1 of 7 Old 05-03-2014, 12:42 AM Thread Starter
birdinmalibu
2009 JK Wrangler
I'm guessing this should be an easy solve. Video attached shows what I'm getting as 2009 JK goes through starting sequence. It continues to try, even after key is out.
http://youtu.be/kz-Fpdr6UNY
Thanks for your help.
birdinmalibu is offline
post #2 of 7 Old 05-03-2014, 02:49 AM
Moezer
2015 JK Wrangler
sounds like u need a new battery or a new starter
Moezer is offline
post #3 of 7 Old 05-03-2014, 07:02 AM
BruceM1964
I have a dodge pickup that is now my plow truck, it does the exact same thing when I don't keep the battery charged up. Don't know why but mopar does some crazy stuff when there is a dead battery, like the truck is possessed.
BruceM1964 is offline
post #4 of 7 Old 05-03-2014, 07:45 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Likely time for a new battery. JKs do some strange things when voltage or amp draw gets low...and a clicking starter relay is one of the signs. Enough voltage to close relay but not enough amperage to turn starter...now, may the battery threads begin.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #5 of 7 Old 05-04-2014, 11:22 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Disconnect the battery for 30 seconds... mine has done something like this twice in three years, my brother's once.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #6 of 7 Old 05-05-2014, 01:46 AM Thread Starter
birdinmalibu
2009 JK Wrangler
Thanks all. It was the battery. However, I spent a few hours Saturday charging it to 100% and then it still didn't turn over. The dash lights were doing all kinds of crazy things. Never the same pattern twice. The headlights came on fine, everything seemed like it wasn't the battery. I thought - for a second - you guys were crazy.
Then when AAA came to tow it to the Jeep Doc, we decided to jump it just in case. It fired right up. So all is good now. Thank you Forum Friends.
Sent from my phone using JeepForum app. If you can read this, it works.
post #7 of 7 Old 05-05-2014, 08:03 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Leave her on a charger overnight to top off the battery!
