starter turns but no fire to cylides - JeepForum.com
post #1 of 6 Old 05-31-2013, 04:23 PM Thread Starter
okiemike
Had my 207 jkWrangler in for a new torque converter. now the shop cannnot start the jeep. The took it back apart to check to make sure they did it right. still cannnot start the starter turns but they say there is no fire to the engine to run any ideas are appreciated.
okiemike is offline
post #2 of 6 Old 05-31-2013, 05:01 PM
HappyTrails
(I'm not being a smart-*** suggesting these, but...)
Check the obvious...spark plug wires connected? Does it have fuel? Is the fuel pump fuse okay?
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #3 of 6 Old 06-03-2013, 03:48 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
The starter turns, but does the engine turn? The reason I ask is that unless the engine turns, there will be no spark....I suspect that when they installed the torque converter they fugged up the starter motor and bendix gear...and that the starter is only spinning free, not engaging the fly wheel.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #4 of 6 Old 06-03-2013, 04:22 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
If the shop cant tell the difference between a free spin and crank/no spark I would doubt the entire job!
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #5 of 6 Old 06-03-2013, 11:14 PM
RockyClymer
RedRock4Wheeler
That is why I asked....the OP was not clear to me.
NRA Life member
post #6 of 6 Old 06-03-2013, 11:55 PM
Speedymcracer01
Check your cps that will cause it to do this. It is located on the transmission they could have done something to it when installing the converter
Speedymcracer01 is offline
