Stabilizer advice - JeepForum.com
post #1 of 15 Old 08-09-2013, 10:08 AM Thread Starter
nathanmilsaps
Stabilizer advice
I have a 12 Rubi JK, 2.5" RK lift on 35" MT ATZ.
The previous owner installed a Skyjacker Dual SS, similar to the pic below (which is not my jeep). I've already done the research and figured out that it's not needed.
I'm looking to remove this one and put on a single SS.
Any recommendations on which one? Procomp? Synergy? OME? Others?
And do I need a kit / bracket?
And where is the best install location?
Any advice is helpful. And since I have to put a single back on, I'd like to do it the best way.
nathanmilsaps is offline
post #2 of 15 Old 08-09-2013, 10:21 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Maybe my eyes are going bad, but it looks like those two SS are all connected only to the tie rod....???
edit....be glad that is not your JK, I am convinced those are for show only as the ends need to be attached to a fixed point, as it looks, they are are just attached to the tie rod....what a joke if that is true.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 15 Old 08-09-2013, 10:25 AM
tonka_yellow
it bolts to the axle is what i am thinking. you can see it in the picture here. http://www.quadratec.com/products/16071_0072.htm
I would get something like this
http://www.quadratec.com/products/16028_0009.htm
and any brand steering Stabilizer.
tonka_yellow is offline
post #4 of 15 Old 08-09-2013, 10:30 AM
RockyClymer
RedRock4Wheeler
Yeah, maybe just the angle of the photo is bad...to the OP, loose them and just get an OEM SS...that is all that is really needed unless you want a bling name brand.
What tricked my eyes is that it looks like two black U bolts on the bottom of the tie rod at the name plate...oh well, comes with age.
NRA Life member
post #5 of 15 Old 08-09-2013, 10:33 AM
ncb
Since you're going back to a single you should definitely go with a relocation bracket. You'll need the mount that attaches to the tie rod wether stock or after market. There's many to choose from. I have the OME SS and relocation kit. On the tie rid end of the SS I'm using the stock bracket.
ncb is offline
post #6 of 15 Old 08-09-2013, 10:38 AM Thread Starter
nathanmilsaps
I just chose that pic as an example of the skyjacker dual ss. I'm not sure how it's installed on that Jeep, but that's not the point.
So a relocation bracket and a single stabilizer is all I need? I don't have any stock parts, I'm assuming. Unless the dual SS is using a stock bracket.
Is the OME only yellow?
I'll take a pic of my setup during lunch time today to see what is stock and not.
post #7 of 15 Old 08-09-2013, 10:47 AM
ncb
You only need one and might as well relocate it. OME is only yellow. All the kits are different and come with different parts. OME kit will lack the mount for the tie rod end.
ncb is offline
post #8 of 15 Old 08-09-2013, 11:12 AM Thread Starter
nathanmilsaps
Here is a pic of mine.
I need new brackets for each end.
post #9 of 15 Old 08-09-2013, 11:14 AM
RockyClymer
RedRock4Wheeler
There is a difference, OEM = Original Equipment Mfgr, OME = Old Man Emu....just to clarify.
NRA Life member
post #10 of 15 Old 08-09-2013, 11:19 AM
broken-wrangler
I believe I have the stock one with only. 15k on it we pulled off my wife's 4 door ruby
Josh Ashley
broken-wrangler is offline
post #11 of 15 Old 08-09-2013, 11:34 AM Thread Starter
nathanmilsaps
Assuming it's for sale, how much? An what year? Why did you take it off?
post #12 of 15 Old 08-09-2013, 01:40 PM
SubAtomicGenius
2011 JK Wrangler
"OOOWWWWW MY FREAKIN' EYES!!!" Skycrapper - what a friggin' joke... what the hell is that frankenstein setup? Lol.
If you're looking for a replacement, I'd go to the Synergy site, get their relocation setup - tie rod clamp and axle bracket. Then any SS will do, even the OEM - I suppose you could even reuse one of your Skycrapper ones (as long as you paint it and toss the ugly boot).
Oh, and post a destruction video of the other SS and their advertising tag on youtube...
SubAtomicGenius is offline
post #13 of 15 Old 08-09-2013, 03:04 PM
Filthy-Beast
Bottom line any decent stabilizer will do, you only need one, duals waste money. Relocate it above bar. FYI: A well setup jeep doesn't need any, they are there to dampen any inputs introduced by uneven roads etc. They do not correct any suspension issues like shimmy, vibrations or DW, they only hide them while the problem gets worse.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #14 of 15 Old 08-22-2013, 07:42 PM Thread Starter
nathanmilsaps
I ordered this.
http://www.jeep4x4center.com/rough-c...-rc-87319.html
That should let me take off the existing dual SS and this kit has both the brackets I need for a higher relocation.
Right?
post #15 of 15 Old 08-22-2013, 11:26 PM
RockyClymer
RedRock4Wheeler
It will work. What FB said, you really don't need one when set up properly.
NRA Life member
