Squealing/whistling noise under load - JeepForum.com
post #1 of 12 Old 08-17-2012, 09:56 PM Thread Starter
ZIMM18
Posted over on JK forum too to get other insight as well. Whats your all thoughts on this?
Long story short, my dad was going to trade in his low miles 07 rubi (21,000) for a 12 because it started squealing under load at mid throttle and 3 dealers couldnt find the cause. He offered it cheap to me, lower than the dealer was going to give him. They thought it was like a throw out bearing, or clutch disc problem. Only happened under 1/2 throttle right around 1500-2000rpm, most noticeable in 4th gear or higher. When the noise occurred, if you rapidly depressed the throttle or let off of it the noise would go away instantly. Clutch never slipped or seemed to have any problems.
Fast forward to today after using my Chassis ears which are remote transmitters that you connect clamps to places you think make noise and you can track down the problem. I think a must for every Jeep owner! hahaha. Anyways, I started with the running grear, trans, bell housing, transfer case and nothing..........Kinda sounded like a intake suction noise in a way....So I threw all 6 sensor clamps on the plastic intake and BOOM found my noise in the intake tract. Now what? Why is whistling/squealing all the sudden, small vacuum leak? I did a BG throttle body cleaning and still the noise......Jeep has a AEM intake but my Dad said it starting making the noise somewhat before the install.
Anybody make an all aluminum intake? Maybe throw one of those tornado spirals in the intake tube?
Not Banned
ZIMM18 is offline
post #2 of 12 Old 08-17-2012, 10:36 PM
mongorunner
2010 JK Wrangler
When you say its a sqeal like noise, does it kind of mimic a exhaust gasket leak?
mongorunner is offline
post #3 of 12 Old 08-17-2012, 10:44 PM Thread Starter
ZIMM18
i know what an exhaust leak sounds like. This is more like a whistling suction squeal sound. Almost like a dry bearing noise in a way. not a puffing exhaust leak.
Not Banned
ZIMM18 is offline
post #4 of 12 Old 08-18-2012, 05:46 AM
Prot
Prot's Avatar
2014 JK Wrangler
Tensioner pulley is one possibility.
Any chance of putting the stock intake back on?
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #5 of 12 Old 08-18-2012, 07:39 AM
JIMBOX
Like Prot suggests--Could be Tension pulley bushing/water pump pulley bushing/Alternator pulley bushing -
I've never heard of an inyake manifold causing a "squeling"-
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #6 of 12 Old 08-18-2012, 07:51 AM
rirrgang
Why didn't you help out your dad with your equipment before he sold it to you?
-Rick
07 Sahara Unlimited
rirrgang is offline
post #7 of 12 Old 08-18-2012, 08:06 AM
Prot
Prot's Avatar
2014 JK Wrangler
Good luck
JIMBO
Cold air intakes make funky sounds on the 3.8L which has been described in various ways including like a cat being skinned alive.
Cold air intake, not the intake manifold.
Prot is offline
post #8 of 12 Old 08-18-2012, 08:32 AM
JIMBOX
Yeah, I've heard of different "whooshing/whistling sounds", but not squealing sounds--and
We can't hearit, so I hope he finds the culprit !
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #9 of 12 Old 08-18-2012, 08:45 AM
Prot
Prot's Avatar
2014 JK Wrangler
JIMBO
Hope he has the lobes for it.
(nerdy Ferengi reference)
Prot is offline
post #10 of 12 Old 08-18-2012, 03:46 PM Thread Starter
ZIMM18
Thanks for the input. My dad is mailing me the stock intake so I can try that. Tensioner or water pump or bearing would squeal all the time you think or change with rpm. This is just a quick whistling kinda sound just at a certain rpm and only at 1/2 throttle as posted above. I tried to make 5 gopro vids from the engine compartment to the drivers seat but it can't pick up the noise for some reason. I'll keep trying it in diff places this weekend to see if it will catch it.
Not Banned
ZIMM18 is offline
post #11 of 12 Old 08-18-2012, 03:47 PM Thread Starter
ZIMM18
He lives in VA, I'm 6000 miles away in Hawaii
Not Banned
ZIMM18 is offline
post #12 of 12 Old 01-02-2013, 07:38 AM
David64
Status? I am having the same issue, 2000 Sahara 4.0L with K&N cold-air intake. The cold air has been installed over 3 years, the "whistling" sound only recently started. I'm pulling my hair out trying to identify it. Mechanic friends say doubtful clutch related. Water pump, fan clutch, and idler pulley 6 months ago new. Have not replaced tensioner pulley.... yet, but I was starting to lean towards that when I came across this thread.
David64 is offline
Whistling Noise - HELP!! w8r TJ Wrangler Technical Forum 23 04-05-2017 06:04 PM
Whistling/high pitched squealing sound hammer44 YJ Wrangler Technical Forum 8 04-21-2012 09:17 AM
whistling noise markpalermo TJ Wrangler Technical Forum 5 12-21-2011 05:48 PM
Squealing/whistling noise 2003 sport 4.0 5sp jus1tym TJ Wrangler Technical Forum 5 03-22-2008 02:40 PM
Whistling Noise Vetteman TJ Wrangler Technical Forum 2 07-02-2005 12:33 AM
