-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Squeaky Jeep (http://www.jeepforum.com/forum/f96/squeaky-jeep-1501323/)
CB17Cubed 03-30-2013 11:14 AM
Squeaky Jeep
Hey everyone,
So I have 2008 Rubicon Unlimited and when I am driving at low speeds, under 35. There is a squeaking noise on the right side of the car. I have tried to point out the exact location of the squeak, though I do think its the front right. It's not a loud squeak, I can only hear it when the radio is off and windows are down. I also don't think it's the suspension because I don't hear any different noises when I go over bumps and I have also pushed down on the fenders and there is no sound.
Thanks for any advice,
CB
Godholio 03-30-2013 12:11 PM
Is it rhythmic, or random? Can you pin it down to anything else like steering input?
CB17Cubed 03-30-2013 12:17 PM
It is rhythmic. Steering doesn't effect it.
redding1327 03-30-2013 12:19 PM
There are any number of things this could be. My first instinct with these type noises would be bushings and coil spring mounting. Godholio brings a good question. I would also like to know, is it a squeak or a "scrape" Sometimes it can be hard to differentiate the two. If it's a scrape, I would check spring mounting and tie rod ends and track bars first. If it's a squeak, start with bushings.
Cooneys08JK 03-30-2013 12:35 PM
Originally Posted by CB17Cubed (Post 15218233)
Hey everyone,
CB
Brakes pads worn down???
Godholio 03-30-2013 01:46 PM
My first thoughts are brakes and wheel bearings.
CB17Cubed 03-30-2013 02:30 PM
It's definitely not the brakes. Replaced them last year, plus the doesn't squeak when I brake.
redding1327 03-30-2013 07:48 PM
could be a caliper sticking. My XJ made a squeak on the pass. side for a long time. It was sticking and not completely releasing. When I pushed the brake it would stop. Let off the brake it would start again. Had nothing to do with the pads themselves. If that's making sense.
maniacal_rick 03-31-2013 10:13 AM
If its rhythmic, it has to be on a rotating part....or is it not constant? I would say wheel bearing or a driveshaft issue.
Coper32 03-31-2013 10:24 AM
Just went through this myself. And I didn't find it fast enough. Check your driveshaft centering joint mine was squeaking for about a week turns out within that week it had gouged out the yoke on the driveshaft and I had to buy a whole new one. Check it out or have it checked out before it ends up costing you more than it should.
CB17Cubed 04-01-2013 10:51 AM
1 Attachment(s)
Well I think I found the culprit of my squeaking.
JTPhoto 04-01-2013 11:46 AM
Hard to tell by the pic what that is!?
I was gonna say could be a front hub u joint getting dry.
ncb 04-01-2013 11:58 AM
Right rear bump stop.
JTPhoto 04-01-2013 12:03 PM
What is causing the right rear bumpstop squeak when you are driving? Is it in contact with something? It should not be touching anything unless you hit a harsh bump.
cyberpyrot 04-01-2013 12:12 PM
yall are both wrong its the rear main coupler to the flux capacitor.
The time now is 11:55 PM.
