Spuerchips TPMS Settings - JeepForum.com
post #1 of 5 Old 03-12-2015, 07:57 AM Thread Starter
bountyhunter
So I bought the Superchips Flascal to correct the 35" tires I put on the 2015 JKU and was under the impression I could also adjust the TPMS threshold with an available free download. So I fix the tire issue and download the offroad TPMS settings and it only puts the value to 0. I can't make it any other value say like 25psi so when my wife drives it she will know if a tire is low. An email to Superchips support tells me it's not available to do that on the new jeeps!? What?!! Doesn't the AEV Procal allow the adjustment of the threshold to whatever value you want? Did I just waste $200 on new TPMS sensors on my new wheel and tire package if the Superchips just turns them off?
bountyhunter is offline
post #2 of 5 Old 03-12-2015, 09:00 AM
Bear9494
2011 JK Wrangler
No since federal law says you have to have the sensors. I use the same unit for my '11. It did try to let me change the pressure setting but never worked. The last update removed that option. I just shut it off since my 35's run at 29 psi.
Bear9494 is offline
post #3 of 5 Old 03-12-2015, 09:08 AM
christensent
2014 JK Wrangler
Well, not entirely... you can still view the tire pressures on the steering-wheel controlled computer (forget its name). Sure beats getting out and checking manually.
christensent is offline
post #4 of 5 Old 03-12-2015, 11:58 AM Thread Starter
bountyhunter
For those of you with the AEV Procal, are you able to set values for where you want your TPMS to be?
post #5 of 5 Old 03-12-2015, 12:22 PM
JIMBOX
I used My AEVPM to set my TPMS at "0" over 5 years ago and haven't had any problem since then--
It's notta dependable warning system and-
Drivers awareness is irreplaceable-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
