Spring Help Please - JeepForum.com
post #1 of 10 Old 12-04-2013, 10:55 PM Thread Starter
06BlueRam
Spring Help Please
I have a 2013 sport with 14's in front and 55's in the rear. My question is that I have bought a set of springs off 2014 rubicon that are 17/18 front and 59/60 rear. I've seen the different spring rates on front but never on the rear. So the 17 on left side front and 18 right side front. Would you do the rear the same way the heavy one on the right ?
06BlueRam is offline
post #2 of 10 Old 12-05-2013, 02:27 AM
1222
RIP John
1222's Avatar
If facing a situation like yours then I would install the stiffer springs on the right side. Both of my JKs seemed to lean to the right. Not sure why or how many others have the same problem but I sure did.
1222 is offline
post #3 of 10 Old 12-05-2013, 09:31 AM
JIMBOX
Heh Heh, yup mine too-
I think that Chrysler engineers (??) designed the spring rate/placement based on gas tank on passenger side, SUMO wrestler drivers--
Maybe not !
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #4 of 10 Old 12-05-2013, 01:43 PM
JoonHoss
2011 JK Wrangler
Actually, It was done as an homage to the CJ, in an attempt to recreate the infamous "CJ lean..."
Word on the street is that they will be offered as part of a 'CJ Retro-Lean' package available in late 2014, to include the lean, hood decals, and a handy tote bag and cap. Package MSRP is rumored to be in the $5,900 range
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #5 of 10 Old 12-06-2013, 06:22 AM
bhoch
Hoss
Mine does not lean. At least I don't see one. Neither when it was stock with 14/56 or after I had put on the 18/59 spriings. Now, it has a RK 2.5" flex system on and does not lean now either...
bhoch is offline
post #6 of 10 Old 12-07-2013, 12:28 AM
1222
RIP John
1222's Avatar
^^^ Are you standing up straight?
1222 is offline
post #7 of 10 Old 12-07-2013, 06:31 AM
bhoch
Ha. Maybe not.
Bill
bhoch is offline
post #8 of 10 Old 12-07-2013, 07:24 PM
suicideking
I would ditch those springs and get a set that matches. I would think you would get uneven tire wear with those mis-matched springs.
suicideking is offline
post #9 of 10 Old 12-07-2013, 08:38 PM Thread Starter
06BlueRam
They only have 14 miles on them. Went straight from dealer to Chux Trucks for lift kit. I only pd $100 for them kind of hate to start over looking again. That was the way it can from the factor. I called the dealer where I bought my Jeep and talked with them before I bought them, they said some of 2014 have different spring rates. Springs are above the tires shouldnt have a wear problem, I can see how the body could lean thought.
post #10 of 10 Old 12-07-2013, 09:06 PM
ncb
Most of the JKs I've worked on for example had a 17/18 front set combo (higher number on passenger side) but I've never seen rear springs that weren't matched. For a little more money you can purchase a brand new set of 19s and 60s springs.
Maybe Jeep caught on to the JK gangsta lean and starting putting a higher rate spring on the right side front and rear.
ncb is offline
