Sport to rubicon front axle swap question? - JeepForum.com
post #1 of 13 Old 11-24-2015, 07:16 AM Thread Starter
Digger838
So I found a 2010 rubicon front housing shafts and gears for a good price and was wondering if it would be a direct swap to my 2014 jk sport?
I would need to buy a locker/ carrier that's all that's missing I believe.
And I would need to regear my rear as well I know.
Sent from a jeeper
Digger838 is offline
post #2 of 13 Old 11-24-2015, 10:15 AM
duneslider
yes, swaps right in. The housings are the same.
07 JKU Wrangler
10 XK Commander Limited
duneslider is offline
post #3 of 13 Old 11-24-2015, 12:26 PM
invest2m4
Define "good price." You can buy a new complete Rubi axle for under $2k.
A locker for that axle will run about $800. If I recall, the ARB goes to 35 spline, so you'd need new shafts as well.
invest2m4 is offline
post #4 of 13 Old 11-24-2015, 01:09 PM
JTPhoto
JTPhoto's Avatar
The Rubi stock carrier is a pricey piece.. Carrier options are limited due to metric bearings in the D44. Remember, the D44 housing is exactly the same strength as the D30 housing. The only advantage of this swap is bigger axles and, ring and pinion. If you are looking for structural strength add a truss too the D44 before instal.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 37x12.50x17 Pitbull Rockers on ProComp 7069 Alloys, AEV Prem Bumper ETC..
JTPhoto is offline
post #5 of 13 Old 11-24-2015, 01:41 PM Thread Starter
Digger838
The housing with a master rebuild kit and a set of 4.88 ring and pinion for 575 OBO but it's still up in the air I just was t sure if the years were comparable
And I would just beef up my Dana 30 because I'm not really doing any hard core off roading but at the same time I still have a payment on it and in order to put new gears in I need to buy carriers/lockers anyway due to the fact that I have 3.21 gears.
Sent from a jeepers iPhone
post #6 of 13 Old 11-24-2015, 10:16 PM
JTPhoto
JTPhoto's Avatar
Originally Posted by Digger838
The housing with a master rebuild kit and a set of 4.88 ring and pinion for 575 OBO but it's still up in the air I just was t sure if the years were comparable And I would just beef up my Dana 30 because I'm not really doing any hard core off roading but at the same time I still have a payment on it and in order to put new gears in I need to buy carriers/lockers anyway due to the fact that I have 3.21 gears. Sent from a jeepers iPhone
You will be looking at another $1500 at least for locker and axles to add to your $575 to get that all together. Now you are over $2k and no labor charges yet. I'm gonna say you will likely hit $2500 before it's in and running.
^^Jeff^^
JTPhoto is offline
post #7 of 13 Old 11-25-2015, 08:50 AM
duneslider
Where do you see NEW complete Rubi axles for under $2k? That has me interested. I occasionally see used ones complete for around that but not any new ones unless you are referring to low miles pull offs as new. Which I do consider the motor I put in my jeep "new" since it was pulled out of a brand new 2011 jk with 22 miles on the ticker. Just curious.
07 JKU Wrangler
post #8 of 13 Old 11-25-2015, 08:56 AM
invest2m4
There was/is a place in OH that was selling them for around $1800, or for $2000 any gear ratio you wanted. Three people in my local club each picked one up and I know a number of people on the other forums that did as well. I installed two of them and they are legit. Not sure I can find the link again though. The price on Rubi axles has come down a lot. I just saw a used front selling for $1500 and it sat for weeks.
post #9 of 13 Old 11-25-2015, 09:18 AM
JTPhoto
JTPhoto's Avatar
I no longer see the point of replacing a D30 with a D44 unless the D44 is either, aftermarket or trussed.
If the D30 is bent and busted, by all means upgrade but you best truss the D44. If you bent a D30 you will bend the D44 as well.
^^Jeff^^
JTPhoto is offline
post #10 of 13 Old 11-25-2015, 09:34 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Lol.
Probably true - especially if the mechanically unsympathetic habits that bent the first one are repeated...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #11 of 13 Old 11-25-2015, 09:50 AM
invest2m4
Personally, if I bent a stock housing, I'd retube it with 1/2" wall and turn the Cs while I was at it. You have a PR44 housing for under $200. And obviously truss it too since it is cheap insurance.
post #12 of 13 Old 11-26-2015, 08:01 PM
Imped
Imped's Avatar
That's what I did, works like a charm. It's a hell of a stout axle now.
OlllllllO
IndyORV
Imped is offline
post #13 of 13 Old 11-27-2015, 09:12 AM
invest2m4
And Dynatrac will also sell the PR44 end forging. Apparently, it isn't too pricey either. Although, the stock one with gussets is just fine.
