sPOD install 2012 JK - JeepForum.com
post #1 of 16 Old 05-13-2012, 07:09 PM Thread Starter
kosmos
Got the sPOD install completed today - now I can wire up my accessories. This sPOD (a bit spendy but so worth it) - sure makes
hooking up accessories less painful and it gives me room for 6 "things" (RI 10" LED bar 1st on the list) Install took about 3-4 hours so plan accordingly.
Here is what comes with the kit from the sPOD guys - I just ordered direct.
Mounted the sPOD in the engine bay - loosen 2 bolts and slip it on (do the passenger side first, slip it up then you can slip the driver side on down - I didn't remove the bolts.
Mount the window frame bracket for the switch holder - you have to pull the moulding off - move the visors out of the way and give it a gentle
but firm tug - those expensive well made wonderful clips :: (I jest) the molding pops right off.
You have to make room for the bracket so I test fitted the moulding marked it and sawed out a notch on each side
The sPOD switch bank goes over the molding so - suggest you center the bracket a little VS what I did and push it all the
way to the passenger side - just 1/4" - 3/8" of play is all there is but before you tighten it all down make sure the visors fit okay. My left one is a bit
snug on the switch housing. (see the last photo)
Here is how I routed the switch control cable - pay attention to the mic if your ride is so equipped (mine is you can see the
mic in the lower left with the white sticker on it)
I didn't have to take the moldinsg off but it was a little tricky fishing it - took my time and I got it down - the driver side
pannel pops right off with those plastic clips (be gentle on removal) Here is how I routed mine and I tie wrapped it down for a
good measure
In the engine bay - locate a firewall foam gasket below the window washer
Here is what it looks like from inside - you gotta get down in there and look up - you can see the black foam gasket - I made
a slit in it for the control connector to fit in
This is what the control cable looks like after it is routed through the foam gasket
Route the cable over to the control box from underneath
Good habit to get into is to ALWAYS inspect connectors prior to plugging them in - see the black goop I picked up with that
upper right connector - easy clean out
Route the control box cables along the back of the firewall and cable them up
sPOD is ready to take connections from your assecories - the kit even includes the spade connectors for the screw down terminals. I soldered mine on and used heat shrink tubbing over the ends.
Here is how the switches look inside (I choose the colors thinking of two rear things (red) two front things (green) - blue for
rock lights and Amber as a spare)
** You can sleep in your Jeep but you can't drive your house **
2012 JK Rubicon in Flame Red, ACE Rock Sliders, LoD Stubby Stinger front, LoD Stubby rear,Rock-Krawler 3.5" X factor Pro mid-arm, RCV ultimate front axles, Warn PP HP, 37" KM2s on AEV Savegre wheels, 10 Factory rear axles,MC front Fenders, Reid Knuckles,aFe Cold Air
kosmos is offline
post #2 of 16 Old 05-13-2012, 07:34 PM
1222
RIP John
1222's Avatar
Very cool and excellent write-up with nice and clear pics.
1222 is offline
post #3 of 16 Old 05-13-2012, 08:09 PM
aristobrat
2010 JK Wrangler
I did a combo like that initially, but after seeing all of the cool switch covers they had on http://www.otrattw.com/, I ended up replacing the ones that I ordered with the sPOD.
Very awesome write-up!!!!
aristobrat is offline
post #4 of 16 Old 05-13-2012, 09:36 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
nice detailed install!
My builds:
and
or follow us on
spyder6 is offline
post #5 of 16 Old 07-08-2012, 07:36 PM
aztec_doc
Is it possible to purchase an sPod and supply your own switches and be able to connect it?
2008 JK Rubicon
aztec_doc is offline
post #6 of 16 Old 07-08-2012, 11:49 PM Thread Starter
kosmos
Yes I think so - check their website - looks like you can order just the source.
kosmos is offline
post #7 of 16 Old 12-24-2012, 09:49 AM
mjpks
Where do you run the wires if you have a manual trans. The hole you used is the clutch slaves slot.
mjpks is offline
post #8 of 16 Old 12-24-2012, 08:13 PM
spyder6
spyder6's Avatar
2010
there is a hole higher up that is available with the manual transmission. the hole used with the manual transmission is used when equipped with an automatic ironically.
My builds:
and
or follow us on
spyder6 is offline
post #9 of 16 Old 05-06-2013, 02:34 PM
mogo116
subscribed. gonna need this in a few weeks when i order mine
98 TJ RED built nicely - SOLD 12/31/12
89 YJ BLACK stock great shape- Traded in 1/5/13
13 JK 2DR RUBI CRUSH ORANGE - picked up 1/09/13
MY BUILD
Registry
mogo116 is offline
post #10 of 16 Old 05-07-2013, 06:01 AM
cyberpyrot
Ok you just gonna mosy on threw this thread post a like to some awesome switches with no further details. I demand you post picture of your set up and part numbers of the replacment switches!!!
I need this switch for my sand scorpion build !!!
I have attention defiiiii hey is that a rabbit?
Thought of the day
Trust people who like big butts they cannot lie...
cyberpyrot is offline
post #11 of 16 Old 05-31-2013, 10:36 PM
fastNugly
Very nice
I need me one of these in mine
fastNugly is offline
post #12 of 16 Old 09-10-2013, 09:23 PM
mlbmd
sPOD use
Now that I have the sPod installed, and have some auxiliary driving lights connected, any suggestions what else I might add?
Not interested in a CB at this time.
Thanks
mlbmd is offline
post #13 of 16 Old 09-11-2013, 05:59 AM
lysol
2013 WK
Thanks
More lights.
MINE > '14 JKUR Anvil
HERS > '13 WK2 Overland Summit V8 Mineral Grey
lysol is offline
post #14 of 16 Old 09-11-2013, 07:19 AM
Turbineguy
Thanks
Selectable lockers x 2.
Air compressor
2012 JKU 4:1 T-Case, 4.88, PR44, RJ3 60, ARB, RCV, JCR front/rear, MC Duroflex, LOD sliders
Turbineguy is offline
post #15 of 16 Old 08-26-2014, 11:37 AM
EvilPeppard
2014 JK Wrangler
Originally Posted by lysol View Post
More lights.
This!
(Oh, and now I am subscribed). Thanks for the write-up! Nicely done.
EvilPeppard is offline
2012 Wrangler Dash Removal/Lockpick Install budmanm3 JK Wrangler Technical Forum 29 05-04-2014 08:30 AM
sPOD & The Source install w/ARB Switches - PICS robncar TJ Wrangler Technical Forum 9 07-08-2012 10:04 PM
2012 JK after market bumper install MrRatt JK Wrangler Technical Forum 4 02-06-2012 05:51 PM
2012 Anyone Install a Block Heater? mini-me JK Wrangler Technical Forum 9 12-09-2011 06:12 PM
TeraFlex 2012 JK Exhaust Spacers, Install Video TeraFlex JK Wrangler Technical Forum 2 10-05-2011 11:22 AM
