post #1 of Old 10-13-2013, 09:54 AM Thread Starter
2jk1cjtj
Spark Plugs
I got almost 70,000 on the clock witch is the best spark plugs to use and should I replace the wires too.
2jk1cjtj is offline
post #2 of Old 10-13-2013, 12:37 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Stock plugs work fine and I would replace the wires if it were me.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of Old 10-16-2013, 10:55 AM
blackjeep05
I replaced my plugs with the Autolite Irdiums don't know the part number off hand but, Jeep seems to run great. As long as you run at least double platinums you will be fine. I went with the Duralast plug wires with the lifetime warranty and so far so good with those. The plug wires can be a bugger to route behind the engine but, other than that its a easy job. I would also change your PCV Valve its only 10 bucks from the dealer and its just good piece of mind. Mine had 80k when I replaced everything and the valve had a little bit of oil seeping by. Engine runs smooth as silk now. One thing if you decide to change the valve you will need a socket to fit over the new one to lightly tap it in so it seals in the valve cover. Otherwise you will get oil seeping all over it. Taking the old one out if you don't want to damage it put a zip tie around the top and pull it up with pliers.
Soccer six in the mix.
blackjeep05 is offline
post #4 of Old 10-16-2013, 05:56 PM
Waltjason
2011 JK Wrangler
Good old stock Champion plugs is what I used. The jeep ran fine with them new so decided why try something different. My two cents worth.
Waltjason is offline
post #5 of Old 10-17-2013, 03:25 PM
ROCKR8R
I heard the 3.8L doesn't like fancy shmancy triple platinum, double iridium, quadruple unobtainium. Stock plugs work fine..
-Dan
ROCKR8R is offline
post #6 of Old 10-17-2013, 03:27 PM
inspmark
2011 JK Wrangler
Yup, stock Champion for me also. Changed mine with 100k, and the still were at about .055".
inspmark is offline
post #7 of Old 10-17-2013, 07:52 PM
Neo1130
2015 JK Wrangler
-Dan
You will hear this for every engine on every sort of vehicle possible... I did go with the regular platinum NGK's though gaped at .045" with no issues so far. Runs great!
Neo1130 is offline
You may not post new threads
You may not post replies
