Spare Tire size - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Spare Tire size
TJ 5.25" Speaker Adapters - NalinMFGSmittybilt Products at Oconee Off-Road!Alloy USA Still Available
Unread 08-17-2014, 03:50 PM   #1
SVM
Spare Tire size
If I go with larger tires dose the spare need to match for the BLD & Stability Control to function Correctly? How big of a tire difference wold it take for the BLD to start applying brake to the larger tire?
SVM is offline   Reply With Quote
Unread 08-17-2014, 05:16 PM   #2
JIMBOX
The ESP/BDS/BLD aren't the problem--
It's the differential/spiders gears on the same axle, shouldn't be "confused" with different size tires, they've been known to go "BOOM"-from the different RPMs introduced-
Spare should be exact same size in diameter--width can give a little, but diameter should be the same-
Strictly for safety purposes the spare should be included in the tire rotations and OF THE SAME MFG-
No you shouldn't JUST GET 4 NOW and plan on updating "LATER", I won't give any acceptable size differences--to chancey-
Good luck
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is online now   Reply With Quote
Unread 08-17-2014, 05:32 PM   #3
SVM
Thank you.
Unread 08-18-2014, 07:07 AM   #4
BlackJeep2013
Ya not a good idea. I did this type of thing when I was young in high school and it was ugly. Both front tires smaller then rears ooopppsss
BlackJeep2013 is offline   Reply With Quote
