Sound/Volume limited with soft top (only) or hard top removed - Page 3 - JeepForum.com
post #31 of 61 Old 09-02-2013, 08:05 PM
Godholio
Originally Posted by ancientspear View Post
Godholio, wouldn't that still leave us with the problem of spraying our cargo area with wiper fluid whenever someone hits the switch? Stopping an annoyance with a real defect is not a fix, I would rather duct tape my windshield to fix a crack than do the jumper thing if it means I can pump wiper fluid in the cargo area.
I don't think either of these wires has anything to do with the wiper or the washer. It would be beyond insanity to run that through the stereo system...they just share a harness with those wires.
The last post on that page, however, is completely accurate.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #32 of 61 Old 09-02-2013, 09:21 PM
JTPhoto
JTPhoto's Avatar
Actually from what I can find in the wiring diagram, the black wire is the ground for all so it would definitely affect the wipers, defroster, and washer. Why send 2 wires all the way to the very back plug if they are not required for something else as well. A simple computer input could otherwise do the same.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #33 of 61 Old 09-03-2013, 08:48 AM Thread Starter
JoeBIII
2014 JK Wrangler
I have to think there's a circuit all the way back to the stereo - that is open if the top is off, and closed with the hard top on (and harness plugged in). We just need to figure out how the wires from the factory hard top harness map back to the radio. Tough for me to do though, as I don't have the hard top harness.
JoeBIII is offline
post #34 of 61 Old 09-03-2013, 09:22 AM
Godholio
Sharing a ground doesn't mean much...a lot of things share grounds without interfering with each other. I'm not saying you're wrong, but it depends on what signals are actually being sent through this harness, which so far nobody knows.
Utah Jeep Crew #148
Godholio is offline
post #35 of 61 Old 09-09-2013, 07:43 AM
ancientspear
Ok I'm finally home. My 2013 (May production I think but I need to confirm) JKUR with dual top and 430N definitely has some volume change happening when you unplug that harness in the rear. Had someone listen to the sub while I plugged the harness in/out at a reasonable volume. What happened? We both heard a definite change but it wasn't as dramatic as many make it out to be. Also, no noticeable change in sound from the sub so it was definitely happening in either the front and/or sound bar speakers.
Question: I seem to recall a sound setting that does volume leveling based on speed but I can no longer locate it. Was I mistaken that we have this and I'm just remembering my old Kenwood/Pioneer decks from previous vehicles? Perhaps this feature on/off is more exaggerated with soft top removed and rather than increasing volume at higher speeds it's really just turning it down at slower speeds. I bring this up because if that feature is in our decks, perhaps turning it off would cancel out this side-effect we are talking about.
ancientspear is offline
post #36 of 61 Old 11-29-2016, 09:34 AM
greydragon
I have a two door soft top. I replaced my rear speakers and they are still quite. Is there a hard top connector in the jeep ?
greydragon is offline
post #37 of 61 Old 11-29-2016, 10:26 AM
JTPhoto
JTPhoto's Avatar
You can put a jumper in the plug so the system thinks the hardtop is plugged in.
^^Jeff^^
JTPhoto is offline
post #38 of 61 Old 11-30-2016, 08:56 AM
greydragon
Where is the plug located?
post #39 of 61 Old 11-30-2016, 09:16 AM
14Sport
Proud Deplorable
14Sport's Avatar
I'm not sure if it's there on a soft top but it's under the rail at the driver side rear corner by the tail gate.
My observations are based on my experiences...YMMV.
14Sport is offline
post #40 of 61 Old 11-30-2016, 10:04 AM
greydragon
You are right I don't have that wiring harness. So why are my rear speakers not working? The fader is set in the middle, equal, new speakers, getting power to them, not sure if it is enough. How much is needed to run speakers ?
post #41 of 61 Old 11-30-2016, 10:19 AM
14Sport
Proud Deplorable
14Sport's Avatar
I'm not sure how much power is required to drive the speakers which are 4 ohm I believe from the factory. So is it just barely audible when you fade all the way to the rear? Maybe a defective head unit. Sorry not much help. I have a base head unit out of my '14 you can have if you want it.
14Sport is offline
post #42 of 61 Old 11-30-2016, 10:28 AM
greydragon
I don't know anything about the base unit. Can you tell me about it, any pictures of it? Thanks
post #43 of 61 Old 11-30-2016, 10:41 AM
14Sport
Proud Deplorable
14Sport's Avatar
The base stereo has no blue tooth, no nav, etc.. Just the tuner, cd, and a front aux jack. I can take a picture when I get home. I'm at work.
14Sport is offline
post #44 of 61 Old 11-30-2016, 10:53 AM
14Sport
Proud Deplorable
14Sport's Avatar
I found a pic online...
14Sport is offline
post #45 of 61 Old 11-30-2016, 11:54 AM
greydragon
Thanks, my unit is like that but has the Bluetooth.
