Quantcast Softer ride swap from RC 2.2 Performance to Skyjacker Hydros? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Softer ride swap from RC 2.2 Performance to Skyjacker Hydros?
Old 11-22-2009, 08:56 AM   #1
DocJake
in therapy
DocJake's Avatar
2009 JK Wrangler
Got my 2.5" Rough Country progressive springs which included Rough Country 2.2 Series performance shocks ("twice the barrel size of other shocks"). I got the lift I needed, but the shocks.. I don't know. Now even highways feel like "rough country" to me. I've heard great things about the ride comfort of Skyjacker Hydros? I don't wheel. Does anyone have experience with these shocks or want to throw me a comment about the RC's? I don't want to be swapping 2 nickels for a dime here.
Thanks ,
Doc
The easiest way to find that missing socket wrench is to buy a replacement
2009 Wrangler JK Deep Water Blue 2/door, Auto Soft Top
Automatic/3.73
2.5" RC Coils/1" MORE-BL/3/4" Levellers/Skyjacker Hydros Shocks/JKS 2" Bumps
17" AEV Argent Pintlers/34.4" GY Duratracs
Rugged Ridge XHD Modular Bumpers, locking ends, grill loop
JKS Links/XHD Modular Bumpers/Locking End Units
SB-XCR8 Winch
http://theadirondoc.blogspot.com
DocJake is offline   Reply With Quote
Old 11-22-2009, 09:20 AM   #2
N2rock
N2rock's Avatar
I actually went the other way around... I had Skyjacker Nitro's (on a pieced together 2.5" BB). Then later switched to the RC 2.5" lift with the RC shocks. Personally I did not notice any difference going from on to the other
But then again, I have a 4dr, so the RC ride is not rough... Anytime I start to think my ride is rough, I just take a drive in my wife's 2dr. It has the TF BB. And I can't even take a drink of soda without spilling it on myself My 4dr rides like a cadillac in comparison... Must be because of the weight difference between the 4dr and 2dr.
for details and info on our JK's, check out http://n2rock.com
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline   Reply With Quote
Old 11-22-2009, 11:05 AM   #3
DocJake
in therapy
DocJake's Avatar
2009 JK Wrangler
Rides like a Cadillac? I love it
I've read the Skyjacker and RC Nitro's are stiff, and their hydros are soft. Both made by Monroe. The RC's I have don't seem to be rated or discussed much either way, so I'm not sure if people consider them stiff or soft.
BTW, just ordered the 1" BL you guys recommended on another thread.
Cheers,
Doc
Automatic/3.73
SB-XCR8 Winch
Old 11-22-2009, 11:49 AM   #4
Imped
TITS
Imped's Avatar
Stick with the RC shocks and let them break in a little. You likely won't notice much of a difference between the RC and SJ Hydros.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 11-22-2009, 12:07 PM   #5
asuperheat
I have skyjacker hydros and think they ride great, If you dont like to get beat up all the time than you will probably like them.
asuperheat is offline   Reply With Quote
Old 11-22-2009, 12:39 PM   #6
planman
Thanks to all Mod erators
planman's Avatar
The RC 2.2 shocks are widely reported to be too stiff for 2 dr JKs.
The Skyjacker Hydros are nice and soft. I ran them for more than 18 months on my 2dr Rubi.
I just upgraded to Old Man Emu Long Travel shocks this weekend. They are slightly stiffer, but still considered a soft shock.
If you want a soft ride with a 2 dr, it is hard to go wrong with the SJ Hydros because they are so inexpensive.
And, to run 35s with stock flares, you will still need to buy some extended bumpstops--even after doing the 1" body lift.
planman is offline   Reply With Quote
Old 11-22-2009, 01:12 PM   #7
wrestlerobx
i have the skyjacker nitro 8000s (i know you asked about hydros but hey thought i would throw in another option) and think they ride no different than stock, i also have a 2.5" lift and nitto terra grapplers. all is well, but like n2rock said it may be different because i have a 4 door
JEEP
wrestlerobx is offline   Reply With Quote
Old 11-22-2009, 03:09 PM   #8
DocJake
in therapy
DocJake's Avatar
2009 JK Wrangler
Thanks guys. Was under my jeep today to look at my bumpstops. I noticed my springs bend backwards a bit. Is this troubling?
Automatic/3.73
SB-XCR8 Winch
Old 11-22-2009, 03:49 PM   #9
wrestlerobx
i would think that is not good, but i dont know how to correct it unless it is that your coil is not in correctly. there are grooves that the coil should seat in and if the top and bottom are "hooked" in correctly then maybe this could cause it
JEEP
Old 11-22-2009, 05:03 PM   #10
planman
planman's Avatar
As long as they are properly seated & installed right side up, there is no problem with your amount of lift.
You can try switching sides if it bugs you.
You need adjustable trackbars & control arms, and in the rear, modified lower perches to fix iit.
Glock Forum
