Soft top thoughts, Fog lights, and BEARS?! OH MY! - JeepForum.com
post #1 of 5 Old 11-03-2011, 07:37 PM Thread Starter
AlanZ
Long time since I posted here, needless to say my Jeep didn't get much attention this summer, Short of a new bumper and winch.
First:
My soft top. Factory one. The other day we got a good 7 inches of snow overnight. As I was lazy, I only cleared off the fenders and hood, what I needed to drive. Hence even with a little driving (No highway) There was still some left up top. I went to my brother's later than night, and when I went to leave the inside of my top was SOAKED. It hadn't dripped anywhere, but it warmed up later, hence I think it was condensation. Or perhaps could my Sailcloth be losing it's water-proofness?
Fog Lights: I removed the factory ones due to my Smittybuilt Stinger bumper. I was gonna put them as rock lights, but I miss having fog lights. Is there any way to grab harnesses that will plug into my factory harnesses up front that won't trip the breakers with some Dually LED lights? Maybe a set of cheap Wal-mart fogs? I know the factory harness didn't like anything but OEM bulbs, but I figured I'd ask. This would just let me keep away from using another switch, and let me use the factory one.
Phew! Sorry for the book guys. Thanks in advance!
Originally Posted by UltimatE View Post
Lifted 4-doors give me wood.
2007 Rescue Green Unlimited X - 33" Falken Wild Peaks, 16" Black Rock steels, Hella 500FF, Smittybilt SRC Rocker Guards and XRC Stinger Bumper
Next: Winch, Snorkel, LOCKERS!
AlanZ is offline
post #2 of 5 Old 11-04-2011, 07:45 AM
Spike6901
Bears?
Soft tops are only good for so much...it is better to keep 'em dry for sure if you can. I used to throw a heavy blanket over the top on my CJ so when I came out in the morning, I could yank it off along with the ice and/or snow. It saved a ton of prep time.
Those cheapo Walmart fog lamps are really, really bad so don't use 'em unless you are just set on it. One wheeling trip and they may not work anymore.
Do a little homework and I will bet you can splice into the harness but I am not a fan of that approach...in reality, if you want some 'real' fog lamps, you will want to run them on a dedicated wire and switch because they will simply draw too much through the factory setup.
Future: '17 WK2
Current: '97 ZJ - Lots of mods
Past: CJ-7, XJ, KJ, JKU
Spike6901 is offline
post #3 of 5 Old 11-04-2011, 09:41 AM
xplosivo1
2011 JK Wrangler
You can run any light you want off of the factory harness as long as the harness is used to activate a relay. The cpu only throws a code ans shuts things off when there is over draw. Under draw does not affect it's operation. (atleast it didn't on my 07, I haven't done any mods to my 11). From my experience and others here the only workaround for using the factory switch is to run it through a relay.
2011 Unlimited Rubicon / Bright White....stock (but it's a very capable stock)
2007 Unlimited Rubicon / Silver / 35 BFG AT 5/13 Gears / Pro Comp 4" lift - SOLD SOLD SOLD
"I can never again see a UNITED STATES MARINE without experiencing a feeling of reverence." -GEN. JOHNSON, US.ARMY
xplosivo1 is offline
post #4 of 5 Old 11-04-2011, 08:28 PM Thread Starter
AlanZ
Like I said I'll probably pick up a set of LED fog's from Dually or whatever the company is called. I was just curious how to wire them in using the factory fog harness and plug that's up front.
Bears? You've never seen The Wizard of Oz?
I might do that next snowstorm with the blanket. That's a good idea.
AlanZ is offline
post #5 of 5 Old 11-04-2011, 09:08 PM
thirstypirate
I really like the blanket idea. I just bought a hardtop tonight off of Craiglist for the winters here in Pittsburgh or I would be adding that trick to my repertoire.
thirstypirate is offline
Thoughts on best soft top for 05 TJ Neeco TJ Wrangler Technical Forum 1 01-14-2011 03:58 PM
your thoughts on this for rock lights SeanWilliams YJ Wrangler Technical Forum 22 12-13-2010 12:36 AM
Thoughts on Smittybilt Soft Top JeepsR4Girls2 Wrangler General Discussion 6 10-11-2010 02:07 PM
Thoughts on Pavement's End Replay Soft top MusicMaverick TJ Wrangler Technical Forum 4 11-06-2007 03:07 PM
Thoughts on Lights? CosmicCreeper YJ Wrangler Technical Forum 2 02-21-2005 11:15 AM
