Soft-top question - JeepForum.com
post #1 of 11 Old 05-27-2013, 03:31 PM Thread Starter
BadBarret
Soft-top question
Is there suppose to be straps on the rear of the factory frame? It seems like mine is missing something because the rear is saggy. Or any suggestions to tighten it up.
BadBarret is offline
post #2 of 11 Old 05-27-2013, 03:48 PM
TheBoss
If you mean in the upper rear above the window ,those are to hold the window when it is rolled up.
The top should end up tight with the rears tucked under the body lip and the header clipped to the windshield. Is this a new factory top?
TheBoss is offline
post #3 of 11 Old 05-27-2013, 03:59 PM Thread Starter
BadBarret
Sorry the the vagueness of my question :P I'm referring to the center cross bar and the rear bar right above the rear window. There are rivets on both as if something use to connect the two. It's the factory frame and a Quadratec replace a top.
post #4 of 11 Old 05-27-2013, 04:34 PM
TheBoss
On a factory top there is a strap between the bows riveted to the frame.
TheBoss is offline
post #5 of 11 Old 05-27-2013, 04:44 PM Thread Starter
BadBarret
Hmm bought this jeep used. Wonder why they would have removed them...
post #6 of 11 Old 05-27-2013, 05:15 PM
Jiblet
for some strange reason they are called "staypad straps".
there are service kits available. but when one of mine pulled from the rivets, I just used some appropriate screws.
Jiblet is offline
post #7 of 11 Old 05-27-2013, 05:21 PM
Jiblet
they tend to get ripped out at the rivets if the top is put up carelessly.
I've snagged my own before and have seen it happen when the front bow is yanked forward to pull the whole top up.
I try to lift the whole top up from the rear to the middle then let the rear portion drop back down while pushing the front the rest of the way. Easiest to by stepping up on the bumper.
Jiblet is offline
post #8 of 11 Old 05-27-2013, 05:31 PM Thread Starter
BadBarret
So do you guys think this could be the cause of my saggy rear end :giggles: the rear corners fit loosely into the body lips and have come out when the front windows have been down and rear rolled up...
post #9 of 11 Old 05-27-2013, 06:37 PM
Jiblet
Yes, without the staypad straps the rear bow will sag and the sail panels will come out from the corners.
A quick search looks like the straps cost around $40-50 per strap.
Part#: 68003640AB
Jiblet is offline
post #10 of 11 Old 05-27-2013, 09:10 PM Thread Starter
BadBarret
Awesome, thanks for the help! But, I'm pretty sure I can make some straps for a long cheaper haha
post #11 of 11 Old 05-28-2013, 08:22 AM
Jiblet
no doubt!
check out:
http://www.jeepforum.com/forum/f9/re...bbing-1240039/
(that's a TJ, but you get the idea....)
Jiblet is offline
