Soft top not laying flat when down - JeepForum.com
post #1 of 7 Old 06-19-2013, 10:05 AM Thread Starter
Iamjhil
I put my soft top down, but as you can see from the photos, it doesn't lay very flat, is there a way to fix this, or am i putting it down incorrectly. I feel like it should lay lower than what it is.
I understand it's not going to lay completely flat, i'm just thinking it's sticking up alot more than it should
-'13 Unlimited
Iamjhil is offline
post #2 of 7 Old 06-19-2013, 10:10 AM
duneslider
You might be able to get it to lay a little bit flatter than that but probably not much. Carefully folding it helps. I thought mine had some elastic straps that would sort of help pull it down too but its been a while since I had my soft top on the jeep.
duneslider is offline
post #3 of 7 Old 06-19-2013, 11:39 AM
rainmn
2014 JK Wrangler
When you do the sunrider part of the fold, you need to pull the material towards the back of the Jeep. Look on youtube...there are several videos.
If you get that first part right, it will help with the top laying flatter.
rainmn is offline
post #4 of 7 Old 06-19-2013, 02:26 PM
ncb
You have the "W" fold wrong when folding the Sunrider portion back. Top pic is wrong, bottom pic is correct.
ncb is offline
post #5 of 7 Old 06-21-2013, 12:19 PM
TOK
Wait, shouldn't the Sunrider sliders be in the locked position when lowering the entire top? I do the W fold when using the Sunrider, but never do that when lowering the whole thing.
TOK is offline
post #6 of 7 Old 06-21-2013, 03:34 PM
ncb
I never use the Sunrider feature, but when folding the top all the way back I fold the "W" as pictured then drop the top back so it's neatly stowed.
ncb is offline
post #7 of 7 Old 06-21-2013, 03:38 PM
takeitsleazy
^Same. It just looks like youre folding it sloppily. No big deal, but to answer your question it CAN sit lower
2013 JK 2DR 3.6L, 1991 XJ 4DR 4.0L, Wife:2008 JK 4DR 3.8L
takeitsleazy is offline
soft top
