Soft top help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Soft top help
10,500 Lb Winch Rugged Ridge1987-1990 Jeep Wrangler Engine Oil Pan for L6 4.2LBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 06-15-2015, 04:00 PM   #1
yanksman34
Soft top help
I have a 2007 Jeep Wrangler Unlimited X 4 door. A buddy of mine gave me a soft top from his 2013 Jeep Wrangler Sahara. I put it on and the side windows dont fit as tightly as I had hoped. If I order the framing for the 2013 Jeep and install into my Jeep, would the windows fit better?
yanksman34 is offline   Reply With Quote Quick reply to this message
Unread 06-15-2015, 05:59 PM   #2
Moezer
2015 JK Wrangler
the soft top has to have all the parts that it came with if not then it wont fit right
Moezer is offline   Reply With Quote Quick reply to this message
Unread 06-15-2015, 08:05 PM   #3
ncb
If the top is from a 2013, the door surrounds would also be from a 2013. I don't see how new surrounds would help.
Post a pic of the side windows. Where are they loose?
ncb is offline   Reply With Quote Quick reply to this message
Unread 06-16-2015, 04:11 AM   #4
mswhitman1
I also have a 2007 Wrangler 4 door. I'm about to post that I'm looking for hardware for a 2007 soft top. I recently contacted Quadratec about a hardware kit they had online from Bestop, the customer service rep said Jeep changed OEM specs slightly from 2010 - newer from the 2007 - 2009 models. It's entirely possible the 2013 top won't fit exactly right on your 2007. Good luck!
mswhitman1 is offline   Reply With Quote Quick reply to this message
Unread 06-16-2015, 11:22 AM   #5
ncb
Originally Posted by ncb
If the top is from a 2013, the door surrounds would also be from a 2013. I don't see how new surrounds would help. Post a pic of the side windows. Where are they loose?
Or did you already have a soft top and just replace the top and retain the original hardware/door surrounds?
Unread 06-17-2015, 07:02 AM   #6
yanksman34
Yes i had the original parts and put the new top on.
Unread 06-18-2015, 02:58 PM   #7
ncb
The new style top doesn't snap into the door surrounds because of the cable style top. You'll need matching door surrounds for it to correctly seal.
soft top compatibility
