Quantcast Soft Top Header Latches - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Soft Top Header Latches
Old 08-10-2007, 12:03 PM   #1
jeepster2003
Hi Friends and Jeepsters:
I just got my second jeep, one with a soft top!
I took off the top and I have not been able to latch the header back on. I was wondering if you all had any tips to getting it latched.
Please let me know.
jeepster2003 is offline   Reply With Quote
Old 08-10-2007, 12:42 PM   #2
Mike72771
Make sure to leave the rear corners of the top unhooked. Fasten the latches up front first then go back to the rear and hook the corners in. Don't worry about pulling down on the corners there is a bit of flex in the tops framework. You should be good to go with a little practice.
Mike72771 is offline   Reply With Quote
Old 08-10-2007, 01:31 PM   #3
gjeepguy
sit it outside in the heat... this will help the fabric stretch. also, if you jeep has the sunrider feature, make sure that the front bow is cliped into the side rail.
gjeepguy
2007 Black Wrangler Unlimited Sahara.
Hard top, Full doors, Power Group, Sirius 6 Disc,
2.5" Teraflex BB, 315x70R17's on AEV Pintler Rims
gjeepguy is offline   Reply With Quote
Glock Forum
