Soft Top Flapping @ Door Surround - JeepForum.com
post #1 of 12 Old 05-16-2011, 10:14 AM Thread Starter
Corleone
So I finally bought a soft top for my JK (it came with a hard top). So I am having a problem when my doors close. The small corner of the soft top window that comes around to the door surround does not catch "just right" when the door closes and just flaps in the wind while driving. I was going to use some velcro on it.....anyone fix this problem before?
Corleone is offline
post #2 of 12 Old 05-16-2011, 11:18 AM
Mol
Disclaimer: I'm Polish
Mol's Avatar
That corner clips into the soft top door frame, it's kind of a L shape, if you will. Unzip the window almost all the way (but not all the way) then push the flapping edge into the door frame, then the bottom of the window into the channel below (just get it started on the bottom), then zip all the way, then finish pushing into the lower channel.
Mol is offline
post #3 of 12 Old 05-16-2011, 12:34 PM
aznjeep
aznjeep's Avatar
2014 WK
x2. The doors are not supposed to "hold" the top in place. The "channel" needs to be tucked into the frame.
-Ken
'96 XJ Sport
'14 WK2 Overland EcoDiesel
'13 JKUR 10A (sold)
'10 JKUR (sold)
'99 TJ (sold)
aznjeep is offline
post #4 of 12 Old 05-16-2011, 01:45 PM
tavic
2010 JK Wrangler
If you are tucking it in to the channel and its just not staying...
I ran in to a similar issue that was my mistake due to mis-storage of them. What you'll need to do is bend the plastic lip that tucks in to the door surround on the window back in to shape with a hair dryer... or on a hot sunny day before you close door make sure the lip is tucked in and the sun with reshape the lip over time.
tavic is offline
post #5 of 12 Old 05-16-2011, 03:23 PM
jstrubberg
2009 JK Wrangler
I had the same problem when I started using my soft top. That "corner" doesn't come around and get secured by the door...it actually needs to be pressed into the groove down the middle of the door pillar.
jstrubberg is offline
post #6 of 12 Old 05-17-2011, 06:36 AM Thread Starter
Corleone
Can anyone post a picture of this. I am just not getting it.
Corleone is offline
post #7 of 12 Old 05-17-2011, 07:14 AM
Jiblet
http://www.jk-forum.com/showthread.p...ts-of-pictures.
Jiblet is offline
post #8 of 12 Old 05-17-2011, 07:48 AM Thread Starter
Corleone
Awesome!! Now I get it. I did not realize there was a flap that you open inside that piece that goes around the surround. Now I get it. Thank you!
Corleone is offline
post #9 of 12 Old 05-17-2011, 06:18 PM Thread Starter
Corleone
I tried it when I got home, no problems. I cannot believe I missed that! I feel like a tool.
Corleone is offline
post #10 of 12 Old 05-17-2011, 08:41 PM
aznjeep
aznjeep's Avatar
2014 WK
We all learn at one point... that's why we're all here!!!
-Ken
'96 XJ Sport
'13 JKUR 10A (sold)
'10 JKUR (sold)
'99 TJ (sold)
aznjeep is offline
post #11 of 12 Old 07-17-2012, 03:03 PM
abradbury84
Hi Jiblet, do you still have these pictures? I am having the same trouble with my 2010 Jeep YK. I thought that the door is supposed to support the sides of the soft top, and it just ends up flapping in the wind on the highway.
abradbury84 is offline
post #12 of 12 Old 07-17-2012, 03:12 PM
SubAtomicGenius
2011 JK Wrangler
Yeah, she's "nice and tight" when it is done correctly! Especially hesitant to put it on the 'proper' way with a fresh, new soft top that hasn't been on before. I used black paracord to make three-or-four inch loops for the zippers to have more hand-hold while zipping it up initially due to the tightness of the install. She's since stretched into place now.
SubAtomicGenius is offline
soft top
Help: where to buy seal for bottom of TJ soft top door surround DowneastTodd TJ Wrangler Technical Forum 4 05-03-2011 12:13 PM
Door surround for a soft top question Phoenyx JK Wrangler Technical Forum 2 04-25-2009 02:18 PM
4-door Soft top "Flapping" Robscj JK Wrangler Technical Forum 3 07-11-2007 10:57 AM
Bolt in sport cages - soft door surround fit? UnsanePyro TJ Wrangler Technical Forum 3 03-01-2007 07:07 PM
Soft top/Door surround seal Tomcatta TJ Wrangler Technical Forum 6 07-10-2006 12:35 PM
