Soft brakes - JeepForum.com
post #1 of 5 Old 08-12-2017, 07:31 PM Thread Starter
oilsuckin_jk
1979 CJ5
Soft brakes
Can't figure this out....hit the brake the other day and it went soft. I checked all the pads and found the left rears were worn out. I changed the rear pads and took it for a test drive. The pedal was still soft and would go to the floor unless I would pump them to stop. First thought was that air somehow go into the system, so I bled them. No change in the pedal. I then checked all the lines and connections for leaks and didn't find any. Next thought is that the master cylinder was letting fluid past the piston, so I changed it...still have a soft pedal (bench bled it too). So next I went over the front and back brakes again and lubed and cleaned everything. Still no good....any thoughts?
oilsuckin_jk is offline
post #2 of 5 Old 08-12-2017, 07:57 PM
mrwhipple
Any crack in the lines?
silver jkur
mrwhipple is offline
post #3 of 5 Old 08-12-2017, 08:12 PM Thread Starter
oilsuckin_jk
1979 CJ5
Not that I can find. It's garage kept and there has never been any fluid on the floor
post #4 of 5 Old 08-13-2017, 09:10 AM Thread Starter
oilsuckin_jk
1979 CJ5
In case this helps anyone in the future, I figured it out (I think)....I'm assuming the problem originally was the master cylinder since the pedal went soft before changing brakes or bleeding anything. After changing the master I think some air got into the abs. I ended up jacking up the back end and running it with the fronts on the ground to activate the abs pump. I then bled the brakes again and the pedal is firm again....
post #5 of 5 Old 08-13-2017, 10:00 AM
mrwhipple
Glad you got it worked out. Good info on the ABS.
silver jkur
