-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   So.. you let air out of your tires.. now what (http://www.jeepforum.com/forum/f96/so-you-let-air-out-your-tires-now-what-1827082/)
orviston 11-25-2013 11:32 AM
so after a wheeling session.. your tires are 10-12 pounds and you need to hit the pavement.
what is the best portable compressor option to air back up again?
COLOUXJ 11-25-2013 11:41 AM
This is probably what I would run. What is "best" depends on a lot of things.
http://www.viaircorp.com/10009.html
orviston 11-25-2013 11:53 AM
good option.. I checked on amazon and there are all the viair optoins and pricing .. their website doesn't list any of that stuff.
mounting.. Mmmm.. have to do some noodling on that.
bogleparsons 11-25-2013 11:55 AM
1 Attachment(s)
Or, if you skipped the gym that day and need a workout!
nwbronco 11-25-2013 12:00 PM
ARB makes a good one. Northridge has it with a bracket that bolts to the brake booster. Small, out of the way and does a good job.
Bob K.
ROCKR8R 11-25-2013 12:37 PM
How about CO2? Powertank or Poly Perfomance.
-Dan
HappyTrails 11-25-2013 01:17 PM
Bob K.
I use that ARB single compressor with the mounting bracket. Love it! I like that it is hidden away under the hood. Fills up my 37's from 10 psi (trail setting) to 25 psi (pavement setting) in about 3 minutes.
orviston 11-25-2013 02:17 PM
that sound nice.. i have wanted raise this question for a while.. but seemed simple. The ARB sound perfect:cheers2:
Metalman 11-25-2013 02:38 PM
I just installed the ARB compressor kit from northridge, like HappyTrails said about 3 minutes per tire. I love it!
XTJake 11-26-2013 09:21 AM
I have the Viair Medium Duty System on my TJ. I like the fact that it has a 2.5 gal tank so I can run an air tool for short bursts if need be. It fills my 35's from 12psi to 35psi in less than 2 minutes a tire. I have to stop between tires and let the compressor breath because I don't have a 100% duty cycle compressor, but that's no big deal.
I also run my ARB off of that system and will run air horns as soon as I get some mounted up.
There are few good options, CO2, portable compressors, mounted electric compressors with or without tanks, York style engine-driven compressors, ect.
I like the Viair system because it's fast, reliable, and there is room to add other air driven devices.
Let me know if you have any questions at all!
-Ryan
orviston 11-26-2013 11:27 AM
Ryan,, is the tank mounted .. or do you just pack it and use it when needed? i have a portable 2.5 gallon but not sure how many tires I can do with just it.. or how to run air tools off it.
Being and enduro guy.. I always try stuff out in the driveway first, ensure i have all the tools needed, so i will be letting the air down and try some refills on my tank alone.
jeepwrnglr92 11-26-2013 12:05 PM
ARB sounds nice. I have a suitcase style compressor in my truck for emergencies. It will fill them relatively fast, and its portable from the truck to the Jeep.
Runs off the battery with 2 alligator clips.
Any model numbers etc on the ARB unit? Price etc.
XTJake 11-26-2013 12:27 PM
I have my tank mounted under the tub and a quick disconnect mounted up high under the hood to keep it clean and dry.
I may have gone with a totally portable kit if I didn't have the ARB in the rear, but I'm really happy with the kit I have overall.
Let me know if you have any other questions at all!
-Ryan
Metalman 11-26-2013 02:36 PM
If you get the ARB under hood mounted compressor make sure it is the ARB-CKMA12 model, that is the compressor for air lockers and/or filling tires. I got the kit with mounting bracket, air hose, and inflator for $319.95
Maertz 11-26-2013 03:38 PM
Dual viar 444cs and a 5 gallon tank and install items for $300~...Will dominate many things.
http://i772.photobucket.com/albums/y...ps86ed2104.jpg
http://i772.photobucket.com/albums/y...ps65534b2d.jpg
The time now is 09:31 AM.
