So, I've tried and tried but... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > So, I've tried and tried but...
Unread 12-20-2013, 09:29 AM   #1
Lenny7
... I can't get it to go off. My oil change warning that is. I've done the turn key to on, compress pedal 3 time slowly under 10 seconds, turn key to lock about 10 times. Also every other combination I can imagine and it keeps coming on. Am i missing something?
08 jku
Lenny7 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2013, 10:02 AM   #2
COLOUXJ
2010 JK Wrangler
you dont turn the key to lock you just turn it to off.
COLOUXJ is offline   Reply With Quote Quick reply to this message
Unread 12-20-2013, 10:02 AM   #3
Maertz
2009 JK Wrangler
08 jku
Mine i turn the key on and pump the pedal 3 times decently quick and turn key off. Start vehicle after and its always gone...Maybe your going to slow?
Wishing I Wasn't Part Of The 'JK' Crowd...
[URL="http://www.jeepforum.com/forum/f96/maertzs-half-build-thread-1857370/"]A JK On Junkyard 60s[/URL]
Maertz is offline   Reply With Quote Quick reply to this message
Unread 12-20-2013, 10:04 AM   #4
number40Fan
2014 JK Wrangler
Try it in the ACC position, then then On position, then shut key off.
number40Fan is offline   Reply With Quote Quick reply to this message
Unread 12-20-2013, 10:11 AM   #5
Lenny7
Finally got it. Not sure what I did different than the other 37 times I tried it. Thanks.
